Latest post Thu, Aug 13 2015 2:10 AM by lumiere. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Feb 2 2013 6:56 PM
    • Andrew
    • Joined on Wed, Jan 25 2012
    • Texas
    • Posts 18
    • Points 210
    Snap to Locators/Markers
    Does anyone know if there is a way to snap to markers/locators when editing within the sequence using the mouse. I know that you can park the blue indicator by turning on  "stop at markers" on the FF/RW tab of "composer settings". However I wish to snap to markers while dragging the mouse (in the same way you snap to the heads and tails of a clip).
    This would be particularly helpful when using the mouse to trim cuts to exact markers.
    Thanks!
    27" iMac 3.4 Intel Core i7 (mid 2011 12,2) Media Composer 7.0.3 Pro Tools 1 After Effects CS6 Photoshop CS6 Lightroom 5 [view my complete system specs]
  • Sun, Feb 3 2013 1:31 PM In reply to
    Re: Snap to Locators/Markers
    Yup - find these commands in the Command Palette, open up the Keyboard settings, and drag the locator-jump commands from the Command Palette to the Keyboard to map them to whatever keyboard commands you want.  I personally like them on Shift-F3 and Shift-F4, but it's Avid, use whatever you want!
    EDIT: Sorry, early when I posted, didn't fully read.  I did think, however, that CMD-drag did this...might be wrong...
  • Sun, Feb 3 2013 4:10 PM In reply to
    • Andrew
    • Texas
    • Posts 18
    • Points 210
    I appreciate the response! I have seen these assignable buttons but what I am looking for exactly is the mouse dragging snap-on, not an assignable key.
  • Sun, Feb 3 2013 4:48 PM In reply to
    • Strypes
    • Joined on Sun, Jul 31 2011
    • Posts 145
    • Points 1,710
    Does holding command cause the playhead to snap to locators? It does for mine.
  • Sun, Feb 3 2013 6:13 PM In reply to
    • Andrew
    • Texas
    • Posts 18
    • Points 210
    I haven't been able to get mine to. I've tried all sorts of combinations including turning specific tracks on & off. I thought that it might have to be turned on/off in a setting somewhere.
  • Thu, Aug 13 2015 2:10 AM In reply to
    • lumiere
    • Joined on Sun, Oct 23 2011
    • Posts 43
    • Points 395
    COMMAND drag will snap on the locator if the track is enables. Then, once your playhead is at that locator, you can COMMAND drag a clip to that position.
