Latest post Mon, Jan 29 2018 5:25 PM by briMestone. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Tue, Jan 22 2013 11:19 PM
    • NEO_AMiGA
    • Joined on Fri, Jan 30 2009
    • Stockholm, Sweden
    • Posts 70
    • Points 835
    ISISClientManager, mount workspace through terminal?
    Hi
    Doing a semi-automated backup thingy here and want to mount workspaces through OSX terminal? What I'd like to do is something like:
    rneo:MacOS henced$ pwd
    /Applications/AvidISIS/ISISClientManager.app/Contents/MacOS
    rneo:MacOS henced$ ./ISISClientManager --user henrik --password yadayada --mount *projekt
    The Client Manager does not seem to take any flags/switches. Is this posible in any way at all? Support can't find any documentation about it and apparently they can't talk to anyone else then their big database. =/ Cheers
    NEO aka Henrik Cednert.
    cto | compositor
    Filmlance International
  • Wed, Mar 27 2013 5:23 PM In reply to
    • Ryan Johnson
    • Joined on Tue, Dec 12 2006
    • New York, NY
    • Posts 53
    • Points 670
    Re: ISISClientManager, mount workspace through terminal?
    Hi there-
    Any answers on this? We were looking to do the same thing...
    I had attempted to build an Isis File Gateway, which is an intermediate server that provides access to Isis workspaces via FTP or SMB. I had hoped that the gateway software would automatically mount a workspace based on an FTP login, but apparently this is not the case. Somebody still needs to manually map a workspace to a drive letter, then share it.
    Please let me know if you find any solutions.
    Thanks!
    -rj
    iMacs, MacPro's, OSX 10.14.6, MC 2019.12, Nexis 2019.12 [view my complete system specs]
  • Wed, Mar 27 2013 6:13 PM In reply to
    • NEO_AMiGA
    • Stockholm, Sweden
    • Posts 70
    • Points 835
    Hi Ryan
    No luck what so ever. My discussion with support wasn't the best and the case didn't end up with the most tech savvy dude... =/
    SUPPORT:
    This should work in theory, unfortunately this has not been tested by enginnering and therefore is not supported. I performed a quick test on one of my macs and was able to launch via terminal by inputing the command "open -a ISISClientManager". But as far as being able to log in and mount workspaces, I am not sure if that is possible and unfortunately we have no documentation on this.
    ME:
    "open -a" would actually not even be remotely close to a bash solution since all that does is to open an application from terminal in it's GUI mode just like when you double click it.
    I want something more like this...
    Oh well, i guess I have to ask at the usergroup/forum if support doesn't have info about it.
    Cheers
    SUPPORT:
    good luck!
    cto | compositor
  • Tue, Apr 16 2013 5:05 PM In reply to
    I'm looking for a similar solution.  I'm running backup software called Retrospect and it doesn't see the ISIS mounts.  Retrospect has the ability to backup through a network, but only through SMB.  Retrospect doesn't support Unity.  If I can find a way to share the ISIS volumes through SMB, it would work.
    Avid Media Composer 4.0.5.2, Nitris, PowerMac 2x2.8Ghz Quad-Core Xeon, 6GB 800MHz DDR2 FB-DIMM RAM, OSX 10.5.6, 300GB internal HDD, 4TB RAID (2x 1.8TB... [view my complete system specs]
  • Tue, Apr 16 2013 5:13 PM In reply to
    • NEO_AMiGA
    • Stockholm, Sweden
    • Posts 70
    • Points 835
    That's odd. OSX or Win? On OSX they are presented just like normal mounts in /Volumes but of type AvidUnityISIS. Not sure what retrospect expects when it comes to type of a volume but I use apps like ChronoSync just fine with ISIS and I have archived with Archivware from ISIS too. In your case I would contact Retrospect support and ask what's up with that. IIRC Retrospect can archive from regular StorNext SAN and other Volumes seen in OSX so I see no real reason for it not to work.
    Sorry for sidetrack but I got carried away.
    Cheers
    cto | compositor
  • Tue, Apr 16 2013 5:25 PM In reply to
    I've been able to use a net use command in windows to connect to ISIS and mount a volume to a drive letter - so it is possible to do it in Windows...I'm just not sure about OSX.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Tue, Apr 16 2013 6:26 PM In reply to
    OSX.  It can see external hard drives, but not ISIS volumes mounted.  Doesn't make a lot of sense.  In Retrospects manual it does state that it can backup through a network, but through SMB.  I have already contacted Retrospect and its official response is that it doesn't support Unity, so ISIS must be the same.  I need to find a way to share all the volumes through SMB.
  • Tue, Apr 16 2013 8:52 PM In reply to
    an ISIS file Gateway server allows for SMB/CIFS shares of ISIS workspaces to be mounted without the need of an ISIS client installer.  you can also use it for FTP access.
     The FunkyDragon
    Happy Editing!
  • Tue, Apr 16 2013 9:11 PM In reply to
    Where can I get info on setting this up?  Thanks!
  • Tue, Apr 16 2013 9:26 PM In reply to
    • NEO_AMiGA
    • Stockholm, Sweden
    • Posts 70
    • Points 835
    2nd hit on google. ;)
    http://avid.force.com/pkb/articles/en_US/User_Guide/en348225
    Moar hardware...!
    cto | compositor
  • Thu, Aug 1 2013 6:40 PM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 140
    • Points 1,570
    The ISIS installer drops a utility on the /sbin folder
    mount_AvidUnityISIS -U <username>:<password> -g WORKGROUP ISIS:VOLUME MOUNTPOINT
    its pretty much the same utility they had with the MediaNet days.
    6 ISIS5000 split in two environments, 25 MC7+SYM NitrisDX, MacPro3,1 MacPro4,1 [view my complete system specs]
    Ted Simbajon
    http://www.tedsimbajon.com
    Head Janitor
  • Thu, Aug 1 2013 7:05 PM In reply to
    • NEO_AMiGA
    • Stockholm, Sweden
    • Posts 70
    • Points 835
    w0000t! Thanks man! Really freakin' strange that support doens't know things like this and/or easily can find it in the database that they search in every single time... =/
    cto | compositor
  • Thu, Aug 1 2013 7:37 PM In reply to
    • briMestone
    • San Francisco
    • Posts 140
    • Points 1,570
    Well, i completely understand why they won't list that on the documentation.
    This requires certain level of guts and attitude to safely use it. Big Smile
    Ted Simbajon
    Head Janitor
  • Thu, Aug 1 2013 8:07 PM In reply to
    Thanks!
    I just need to figure out the mountpoint.  I have been typing in: Volumes/workspace, but that isn't working.
    mount_AvidUnityISIS -U assist:password -g WORKGROUP isisengine1:workspace /Volumes/workspace
  • Thu, Aug 1 2013 8:34 PM In reply to
    • briMestone
    • San Francisco
    • Posts 140
    • Points 1,570
    does the mountpoint exist?
    you may need to add a
    mkdir /Volumes/$VOLUMENAME/
    Ted Simbajon
    Head Janitor
