Latest post Sat, Apr 26 2014 12:50 AM by usatraveler. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • Mon, Jan 28 2013 5:42 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Canon C100 import settings and workflow
    bobcat:
    The Canon C100 only records 24p in native 23.98. The other framerates (30PF, 25PF) are PsF and recorded in an interlaced wrapper. You have to tell Avid manually that they are Progressive clips.
    Yes, that was the reason to why I asked if this was only when using media from Canon cams
    rdmartin:
    how do you tell avid this upon importing/transcoding....??
    Add " field motion " to the selections in your bin, you will get a scrolldown to select what it is.
    Michael Walcott:
    I have observed this with Panasonic and Sony footage.
    If so this same workflow is what you want to use.
    Tomas
  • Tue, Jan 29 2013 6:17 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • Southwest, USA
    • Posts 522
    • Points 6,075
    .....and you have to be in a 1080/25 Progressive timeline
    and change the field motion from interlace to progressive.
    Avid MC 6.5.2.1 with 27"iMac 2.8GHz Intel i7 OSX 10.8.3, 12GB memory, ATi Radeon HD 4850, Caldigit Raid [view my complete system specs]
  • Wed, Jan 30 2013 1:13 PM In reply to
    We've been getting some aerial drone footage that's shot on a small Sony HD camera that outputs .mts files.  The best solution I found was to use Premiere CS6 to get my selects and then transcode to DNxHD220 for Symphony.
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
  • Fri, Feb 8 2013 3:01 AM In reply to
    • bobcat
    • Southwest, USA
    • Posts 522
    • Points 6,075
    The newest version of Clipwrap will rewrap the AVCHD files from the C100 and make the files visible to Avid nd other NLE's as progressive files.
  • Wed, Mar 26 2014 7:27 AM In reply to
    OK. I have some footage recently shot on C100 and want to work with it in Avid MC 7.  Whats the best way for minimal quality loss?  25P... Import? Link to AMA? Transcode? HELP!
  • Wed, Mar 26 2014 7:49 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    davidblumenfeld:
    Hi David, ama is the way to go, below is a link to some workflows and I just bumped that thread, was about time as new users arrives to these boards quite frequently
    http://community.avid.com/forums/p/115980/724495.aspx#724495
    Tomas
  • Wed, Mar 26 2014 9:58 AM In reply to
    • cccu tech
    • Joined on Fri, Jun 17 2011
    • Posts 118
    • Points 1,350
    Assuming your footage has been shot at 25PF:
    Create a 1080p/25 project, AMA Link, and then transcode to DNxHD 120 or higher.
    Avid 5.5.3 Snow Leopard 10.6.8 2007 2x 2.8Ghx Quad Mac Pro 4GB Ram [view my complete system specs]
  • Thu, Apr 3 2014 2:26 PM In reply to
    Hi.
    Working on this now. For some reason the footage is reading on avid as 25i.  Also, when I go to transcode, DNxHD is not an option. ANy ideas how to get that option on? THanks.
  • Thu, Apr 3 2014 2:30 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Just switch your project to what was shot with the cam, my guess is Hd, if you have shot it yourself just check what the cam is set to.
    If it it media brought from someone else, Media Inspector is a nice free tool to examine the files.
    Tomas
  • Thu, Apr 3 2014 4:16 PM In reply to
    THanks. Worked. Now getting a disk unix error, though...hmmm
  • Thu, Apr 3 2014 7:12 PM In reply to
    OK now. Was a wierd thing with that disk,but going fine onto another one. Now, wondering what the best transcode settings are.  DNxHD or XDCamEX which I read was better, but I dont see any difference. Any thoughts? THanks!
  • Thu, Apr 3 2014 9:13 PM In reply to
    So, any thoughts on best codec to AMA-Transcode the C100 footage to for editing on Avid MC7? Thanks!
  • Sat, Apr 5 2014 11:32 AM In reply to
    rdmartin:
    Why would you link to ama volume, which gives you down converted clips at h.264(1080i50) and than have to re-upconverted an already degraded media back up to 1080p25??
    AMA is not misinterpretting the footage.  AVCHD IS H.264.  As you are shooting 25fps, it is being recorded as PSF which is progressive within an interlaced container.  So AMA IS reading the footage correctly when it says H.264 and 50i.  Just set your project to 1080/25p AMA link and transcode to whichever flavour of DNx you want.  If you're finishing for broadcast I'd recommend DNx185 or 185X.
    The tech specs for the C100 can be found here.  Read the section on recording.
    Andi
    HP ZBook G5 15 2.6Ghz 6-core i7 Nvidia Quadro P2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.8 MacbookPro 15 2019 6 core 2.6GHz i9 32GB RAM... [view my complete system specs]
  • Fri, Apr 25 2014 9:28 PM In reply to
    • ppohio
    • Joined on Sat, Jan 28 2012
    • Posts 111
    • Points 1,435
    Anybody have experience using ClipWrap for this with Avid? We just got a C100 and are going to be shooting a huge variety of projects on it. I can AMA the AVCHD "file" (folder) into Avid and playback is great. When I ClipWrap the files same as source, Avid locks up playing back AMA.
    For the time being I am going to just AMA the originals, but if anyone has had a similar experience with ClipWrap I'd love to know if you had any solutions. The other folks on my team aren't very good with media management and the idea of having a lot of AVCHD folders floating around and tons of clips all named 000XXX.mts is making me very antsy! Stick out tongue
    We're using ClipWrap for our workflow in Premiere so it would be great to have the same workflow for Avid. I checked the wrapped files in Premiere and they playback perfectly.
    Macbook Pro 15" 2.2Ghz, Intel Core i7, AMD Radeon HD 6750M, 8GB RAM OS X Lion 10.9.1 Avid Media Composer 7.0.3 [view my complete system specs]
  • Sat, Apr 26 2014 12:50 AM In reply to
    I tried ClipWrap a couple of times in Avid, with the same result - massive lock-up.  That's too bad, because it's the best software I've found for managing AVCHD, developers are helpful and responsive, and it would potentially be my immediate go-to every time, but it just isn't working the way I hoped.
    So, I just stick to AMA, and go through and rename clips in the bin as soon as I link them.  I also make sure I organize my raw folders - generally by date.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.5, Avid Media Composer 2020.6 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
