Latest post Tue, Apr 30 2019 3:32 PM by Parallaxrider. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • Tue, Dec 18 2012 10:27 PM
    • scene24
    • Joined on Tue, Jun 7 2011
    • Posts 6
    • Points 110
    Blackmagic Mini Monitor audio output MC 6.5
    Just got the Ultrastudio Mini Monitor for monitoring to a 42" LCD through HDMI (for ofline work). It works great for the price, little-to-no lag with trimming, great quality video out. Very happy with my perchase.
    My only problem is that there is no seperate control for audio output. I want to output my audio to my Line-Out jack (instead of the Blackmagic), but I can't change the setting in the "Audio Project" -> "Hardware" dialogue.
    In the Blackmagic panel in System Prefs there is no option to turn audio out off...
    Is there some other way to change this? It sucks, since I don't want to loop-back to my sound system... Help will be appreciated. Thanks!
    System:
    15" Macbook Pro w/ Retina Display (i7 2.3ghz, 16gb)
    Black Magic Ultrastudio Mini Monitor (Drivers up-to-date)
    15" Macbook Pro with Retina Display: Intel Core i7 @2.3Ghz, 16GB RAM, 256GB SSD, Nvidia GeForce 650m 1GB Avid Media Composer 6.5 Blackmagic Ultrastudio... [view my complete system specs]
  • Tue, Dec 18 2012 10:31 PM In reply to
    Re: Blackmagic Mini Monitor audio output MC 6.5
    I think its designed thgis way meaning, Avid will output sound only thru the BM box if its attached. You yould use a line out of the TV to monitor audio, or loop back to a mixer connected to your computer speakers.
  • Tue, Dec 18 2012 10:39 PM In reply to
    • scene24
    • Posts 6
    • Points 110
    Yeah, I was beginning to suspect that. Well, could be worse...
  • Wed, Dec 19 2012 5:05 AM In reply to
    • Kyle
    • Joined on Tue, May 29 2012
    • Posts 135
    • Points 1,685
    Try contacting blackmagic support. They might have a workaround. If not maybe they'll add the feature in the future, doesn't seem like it would be too difficult to add. Any idea if the same thing happens when using the sdi output?
  • Wed, Dec 19 2012 5:31 PM In reply to
    Its not just BlackMagic. Its the same with any hardware attached. There assuming your using the audio outputs of your I/O box to a pair of dedicated monitors.
  • Wed, Dec 19 2012 5:40 PM In reply to
    • Kyle
    • Posts 135
    • Points 1,685
    That's a problem when the i/o box doesn't have any audio outputs.
  • Wed, Dec 19 2012 8:06 PM In reply to
    Yes, that is correct. One of the limitations of this BM box and the AJA T-Tap is your only gonna get audio thru the device your monitoring through.
  • Thu, Jun 6 2013 8:39 PM In reply to
    • Nick
    • Joined on Tue, Apr 9 2013
    • Posts 18
    • Points 180
    Pprobably a dumber question but did you try going to "Sound" in system preferences and changing the output back to the mac?
    Macbook Pro, 2.6 GHz, i7, 16GB DDR3, 500GB SSD, NVIDIA GeForce GT 650M 1024MB [view my complete system specs]
  • Wed, Jul 17 2013 8:06 AM In reply to
    • soundbase
    • Joined on Wed, Jul 17 2013
    • Posts 4
    • Points 70
    I had the same problem with the decklink mini monitor card. Try this, works perfect for me!
    http://www.lindy.de/HDMI-Audio-Extractor-mit-HDMI-Bypass.htm?websale8=ld0101&pi=38091&ci=2003
  • Thu, Oct 24 2013 5:19 PM In reply to
    Doesn't that give you a delay in your audio?
    MC 8.3.1 | MacPro6,1 | OSX 10.10.1 [view my complete system specs]
    Twitter: @robindejongedit
  • Thu, Oct 24 2013 6:35 PM In reply to
    • soundbase
    • Posts 4
    • Points 70
  • Thu, Oct 24 2013 6:47 PM In reply to
    That sounds good. Do you have any delay between your computer and your playback? I saw the setup of a friend of mine with the Mini Monitor, but there was this splitsecond delay between the source/record monitor and the playback monitor.
  • Thu, Oct 24 2013 6:57 PM In reply to
    • soundbase
    • Posts 4
    • Points 70
    No, no delay with computer monitor and video monitor with 6.5.
    But if you playback desktop sound over mini monitor as sound output device, audio is delayed, so you have to choose built in audio for that.
  • Thu, Oct 24 2013 7:28 PM In reply to
    Thanks for the fast response, I'm planning to use the Mini Monitor as well. And thanks for the headsup about the desktop audio. I wanted to have that seperate under my mixer anyway, so that won't be a problem. And I imagine if I would get any delay through the card, the audio that goes through the same card would get the same delay as well.
  • Thu, Mar 6 2014 4:58 PM In reply to
    • kellyv
    • Posts 413
    • Points 4,840
    Hi there,
    Was thinking of getting the Mini Monitor for use with my Retina Macbook. Running 7.0.3 and Mavericks 10.9.1. Any issues with this if you have experience on these versions?
    And I too would like to use the audio jack from the Macbook. Did Black Magic change anything to allow this?
    Thx
    Late 2013 MacBook Pro 2.6 GHz Retina 15" with 2 TB Displays OSX El Capitan 10.11.3. Media Composer 8.5. BM Ultra Studio Mini Monitor. BM Desktop Video... [view my complete system specs]
    Editor
