Latest post Fri, Dec 7 2012 12:09 AM by Randall L. Rike. 7 replies.
  • Thu, Dec 6 2012 9:45 PM
    • Lenny V
    • Joined on Tue, May 29 2012
    • NYC
    • Posts 27
    • Points 365
    Question regarding importing files with vid and audio into Avid MC
    Hey guys
    I have searched everywhere for an answer and simply couldn't find anything so I apoligize if this is an elementary question but here goes:
    We are running Avid Unity with multiple partitions, one per project. Sometimes an assistant editor would import a file that has video and audio, and the audio would mistakingly end up on another drive. So audio shows up offline while video shows up online when proper drive is mounted. My question is, is there any way that I can check the metadata to see which drive the audio was imported to?
    This would save me the trouble of mounting all our drives (about 60 of them) to try and figure out which one has the audio.
    Our specs are. Avid Unity
    Media composer 4.0.5
    Macs and PC's
    Work: MacPro quad core 2.66ghz XEON 6GB Ram AVID MC 4.0.5 Home: Macbook Pro 15" 2011 2.0ghz 12 gb ram Avid MC 6.5 [view my complete system specs]
  • Thu, Dec 6 2012 10:31 PM In reply to
    Re: Question regarding importing files with vid and audio into Avid MC
    I'm going to move this to the Unity Work Groups Forum so our Unity gurus can get a look at it.
  • Thu, Dec 6 2012 10:52 PM In reply to
    • Chris Hocking
    • Joined on Thu, Mar 13 2008
    • Melbourne, Australia
    • Posts 179
    • Points 2,070
    The last known wereabouts of the media can be found in a "Drive" bin column.
    Make sure your editors check the "Media Creation" settings prior to cutting.
  • Thu, Dec 6 2012 10:58 PM In reply to
    • Lenny V
    • NYC
    • Posts 27
    • Points 365
    But the "drive" bin column only shows you where the video was loaded. If video and audio were loaded to two separate drives it doesnt show you which drive the audio was imported to.
  • Thu, Dec 6 2012 11:09 PM In reply to
    I'm not sure if this will work in a Unity environment, but try selecting the audio file in it's bin and then File>Reveal File. That should show the actual file and it's location.
  • Thu, Dec 6 2012 11:14 PM In reply to
    • Lenny V
    • NYC
    • Posts 27
    • Points 365
    The problem is its one file say: "Interview005.mp4" the video will go to "drive1" and the audio will go to "drive 2" accidentally. So when I click on the clip in the bin and chose "reveal file" it will only reveal the files if the drive is mounted. Since we have 60 drives it would be extremely inefficient and time consuming to mount each drive until I find the one that will bring the media online / reveal file
  • Thu, Dec 6 2012 11:46 PM In reply to
    • Chris Hocking
    • Posts 179
    • Points 2,070
    Ahhh... I see what you mean now Lenny. Sorry, I didn't read your original post properly.
    I don't really see how you've done this - as the Media Creation settings always default to setting both the Video & Audio to the same drive, even if you're seperately video and audio. But, assuming that the assistants accidentally manually set the drives to different places...
    The only way I can think to do this jump onto the Unity and do a "Search" through ALL the workspaces for the rogue audio files...
  • Fri, Dec 7 2012 12:09 AM In reply to
    As far as I know there is no metadata that will inform you of the audio-only location with the Workspaces unmounted. You could ustmount the Workspaces one at a time, until the media comes online :)
    Or, if you mounted all the volumes, you could use Media tool, which offers "Media Files" as a filter option for the search.  You could then sort on the Audio column, to group them separately from the video, and then check the Drive column for their location.
    Otherwise, to fix it, mount all the Workspaces and just Cconsolidate the clips, specifying a single Workspace for both audio & video.
    (wwld)
