Latest post Tue, Nov 20 2012 1:45 AM by AndrewAction. 7 replies.
  • Mon, Nov 19 2012 10:08 PM
    Bus Error/Crash upon Launching Project - Avid MC 5.0.4.4
    I'm attempting to install Avid Media Composer 5.0.4.4 on my MacBook Pro but receive the crash error:
    "Bus error" in thread "MainThread", at address     0x0
    when trying to open a project (either one I made new or one from my other system).  In short, the program launches fine, but crashes after choosing a project.  I've tried uninstalling and reinstalling as well as creating a new user and dumping MCState.
    I am running a new MacBook Pro with
    - OS 10.8.2
    - 2.6 GHz Intel Core i7
    - 16 GB of 1600 MHz DDR3
    I am running Avid MC 5.0.4.4 on my Mac Tower so I want to have a matching version on my laptop.
    Any ideas?
    Filed under: ,
  • Mon, Nov 19 2012 10:21 PM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,043
    • Points 12,980
    Re: Bus Error/Crash upon Launching Project - Avid MC 5.0.4.4
    don't think you wll get MC 5 to run under mountain lion. 6.0.3 and 6.5 are the only versions qualified to run on 10.8
    See version matrix here
    Media Composer Nitris DX 2018.8 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Mon, Nov 19 2012 10:38 PM In reply to
    outpostbc:
    Well in that case, do you know what my best solution will be?  If I decide to upgrade, will I be able to use 5.0.4.4 on my Mac Tower (which is a 32 bit machine) and 6.5 on my MacBook Pro (64 bit) by activating one and deactivating the other (and vice versa when i want to switch back)?  Or does it not work that way?
  • Mon, Nov 19 2012 10:54 PM In reply to
    • Mark Renz
    • Kansas City, MO
    • Posts 1,043
    • Points 12,980
    I think the licensing procedure has changed with 6.5 so I don't think it is as simple as deactivating/activating. The activation codes are different AFAIK.
    Does your Mac Pro tower support the 64 bit OS? If so, you may want to take it up to an OS that can run 6.5 to keep it in line with your laptop.
  • Mon, Nov 19 2012 11:01 PM In reply to
    outpostbc:
    I don't believe it does support the 64 bit OS.  Hope I'm not SOL, because I definitely don't want to have to buy a full version of MC just for my laptop.
  • Mon, Nov 19 2012 11:55 PM In reply to
    Which Mac tower?
    I have 10.8.0 running happily on a 2008 Mac Pro here. FWIW I have not installed Avid on it only because it has a Decklink Extreme 3D card that Avid does not seem to like.
  • Tue, Nov 20 2012 1:41 AM In reply to
    There are certain 2008 Towers that can handle it.  I believe mine isn't one of them though.
  • Tue, Nov 20 2012 1:45 AM In reply to
    I did not think mine was either, so I took out the current bootdrive, added a new drive and installed 10.8. Happily it worked.
