Latest post Wed, Oct 24 2012 1:00 PM by smrpix. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Oct 23 2012 8:01 PM
    • Dwight
    • Joined on Thu, Aug 26 2010
    • Buhler
    • Posts 80
    • Points 1,060
    MC 6.5 to After Effects?
    Hi all, Im working on a few ads and need to export my final sequence to another guy (who's not in my network or linked in anyway to my computer) for him to add some effects.
    All the tutorials I see assume that you are using the same computer for both activities.
    I am wondering what the best way is to get the sequence to him to allow him to add effects and then be able to get it all back into a timeline where I can still edit the timeline.
    Hope that makes sense. Any help would be appreciated.
    iMac 27" Processor 3.8 GHz Intel Core i5 Memory 40 GB 2400 MHz DDR4 Graphics Radeon Pro 580 8GB Software Mac OS X Mojave 10.14.6 Media Composer 6... [view my complete system specs]
    Dwight Buhler   http://www.dwightbuhler.net/
    Filed under: ,
  • Tue, Oct 23 2012 8:40 PM In reply to
    Re: MC 6.5 to After Effects?
    If he's not connected to your computer via a network, you cannot generate a QT ref file. Instead, export a Quicktime movie at the highest quality and lowest compression (or no compression) that your storage and transfer capacity will allow. Best to click the "custom" button on the export options window from the export tool and custom build a profile. THe "Format Options" button gets you deeper into setting up the profile.
  • Tue, Oct 23 2012 8:46 PM In reply to
    • Dwight
    • Buhler
    • Posts 80
    • Points 1,060
    Thanks Larry, I was afraid of that, but hoping for a different answer.
  • Tue, Oct 23 2012 9:10 PM In reply to
    If it's at all possible, can either computer be transported so they can be hooked together? Then, you could do a QT ref export to his.
  • Tue, Oct 23 2012 9:14 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,439
    • Points 17,745
    I've had very good results using a self-contained aaf to AE CS6.
    Coming back the other way hasn't been as elegant, I usually end up rendering a flattened DNxHD from AE and cutting it into the timeline.
  • Tue, Oct 23 2012 9:24 PM In reply to
    • Dwight
    • Buhler
    • Posts 80
    • Points 1,060
    That's good news. Am looking at the Export settings now for AAF. There's a dropdown menu called Export Method. with the choices:
    Link to Media, Copy all Media, Consolidate Media, Video Mixdown.
    I guess the first is not right, but what about the others? Also, these are very simple timelines... no fancy Avid tricks except for a dissolve and a title created in Marquee.
    Thanks for the help!
  • Tue, Oct 23 2012 9:56 PM In reply to
    • smrpix
    • Posts 1,439
    • Points 17,745
    Consolidate Media.  Then either embed in AAF or send it to a folder - both options will come up.  AE will be able to find them either way.
  • Tue, Oct 23 2012 10:01 PM In reply to
    You should look into Boris Transfer AE.  http://www.borisfx.com/XML-Transfer/
    There's a free trial (I believe 14 days).
  • Wed, Oct 24 2012 2:24 AM In reply to
    Doesnt the Free Automatic Duck do this?
  • Wed, Oct 24 2012 1:00 PM In reply to
    • smrpix
    • Posts 1,439
    • Points 17,745
    Automatic Duck is no longer required as of CS6.  (That's part of why it's now free.)
