Latest post Fri, Oct 19 2012 5:16 PM by Abeyta. 2 replies.
  • Thu, Oct 18 2012 7:46 PM
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    add AFD code for file based delivery?
    Does anybody know if MC/Symphony can add AFD codes for a file based delivery to the stations? I see the new AFD coding feature in v6.5 but the marketing literature is kinda vaque on the specifics. Anybody know how to do this? I was asked by a local station to add AFD flag of 1111 on line 11 of a commercial spot. Thanks for any help.
    Derrick
    Mac Pro 2013 6 Core 3.5ghz, MC Symphony 8.9, 32GB RAM, D700, OS 10.10.5, Ultrastudio 4K, Pegasus2 R6 24TB [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Fri, Oct 19 2012 1:11 PM In reply to
    • Mike Brodeur
    • Joined on Tue, Apr 15 2008
    • Burlington, MA
    • Posts 29
    • Points 420
    Re: add AFD code for file based delivery?
    Yes, it's quite simple.  As a first step, eanble the AFD column in the Bin display so you can see the AFD values assigned to each sequence.  Next, select the sequence, right click and "Modify".  Once the dialog comes up, use the switching widget at the top to select "Active Format Description".
    This will bring up a dialog that lets you select whichever AFD value you want.  Simply select the value you want, an "OK" to confirm.  If your sequence already has a D1 track, then you're done.  If it doesn't then one will be created for you and a dialog will pop up telling you the details of using the D1 track.
    When you do a transcode, mixdown or consolidate, the AFD values in the D1 track will come along for the ride.  Note that Avid keeps ancillary data (AFD is a type of this) in a separate MXF file from the video, just like it does with audio.
  • Fri, Oct 19 2012 5:16 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 200
    • Points 2,485
    Thank you for the detailed information Mike. I look forward to using this function in version 6.5 when I can upgrade in the future. I am currently stuck on v5 as my current Mac Pro isn't supported anymore on v6. Waiting for Apple to come out with a new Mac Pro line.
    Phoenix, Arizona
