Latest post Mon, Oct 8 2012 9:07 PM by Larry Rubin. 2 replies.
  • Sun, Oct 7 2012 3:22 PM
    • mar/cus
    • Joined on Mon, Nov 7 2011
    • sweden
    • Posts 102
    • Points 1,420
    Mbox mini with media composer?
    I'm looking for some audio monitors, so I'll need to get an external sound card. Can I use Avid's Mbox mini with media composer, or is it just for pro tools?
    I can't afford a video hardware like Mojo DX, but what are really the advantages with video hardware except that you get audio monitor output and the ability to connect a client monitor?
    MacPro 2013 Quad-Core - Dual AMD FirePro D300 - 32GB Memory, PROMISE Pegasus2 R6 18 TB, Blackmagic Ultrastudio Express, Avid Omni HD Native, Artist Mix... [view my complete system specs]
  • Mon, Oct 8 2012 8:58 PM In reply to
    Re: Mbox mini with media composer?
    Sync.
    And that's enough of an advantage when working with a broadcast monitor or even a good LED TV.
    You could take a look at AJA T-TAP. It's pretty reasonable.
    MacBook Pro 16 (2019), 8GB 5500MX, 32GB RAM, OSX 10.15.4, MC 2020.4 || Mac Pro 8 core 2.4 Ghz (Middle 2010), 40 Gb RAM, BM Mini Monitor 4k, GTX970 4GB... [view my complete system specs]
  • Mon, Oct 8 2012 9:07 PM In reply to
    marcus:
    ...what are really the advantages with video hardware except that you get audio monitor output and the ability to connect a client monitor?
    You get additional input/output connectivity sometimes far beyond the basic firewire single connection. So if you need to access legacy SD material from analog sources, you'll need the additional hardware. Also, with Avid Mojo DX or Nitris DX, you will get additional resolutions to work at. And you'll be outputting a properly calibrated video signal to waveform/vector scope displays as well as a true NTSC video monitor, which is critical when performing sophisticated and subtle Color Correction or grading. A computer monitor is not suitable for high level color corrections work intended for broadcast.
