Latest post Sat, Oct 6 2012 5:26 PM by Lemuriatv. 2 replies.
  • Sat, Oct 6 2012 3:55 PM
    • Lemuriatv
    • Joined on Wed, Mar 5 2008
    • Czech Republic
    • Posts 229
    • Points 2,810
    Cannnot export or videomixdown AMA sequence
    A have problem with AMA SD PAL sequence (made with HD MOV files on external disc).  I need export it or make video and audio mixdown but nothing works. When I try this export (same as source with Avid codec) or videomixdown run only few minutes then freeze (and I have to restart Avid). At the end when I try export as custom settings (Video and audio, RGB, 1024x576, Odd, 16:9 I get this message:
    ________ Exception Report ________________________
    Exception Code: C0000005 ACCESS_VIOLATION
    Fault Module:   01:00023651 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\MSVCR90.dll
    Fault Address:  78544651 Symbol not found
    ________ Stack Dump _________________________________________
    AVID SYSTEM DUMP - Sat Oct 06 17:33:24 2012
    ________ Memory ________________________________________________________
    numPtrs:      594612
    numHdls:      06781
    totalPtr:     0x038861dd (59269597)
    totalHdl:     0x0005d558 (382296)
    ________ Current Program Stack _________________________________________
    ________ System Configuration __________________________________________
    System software: Windows NT Version 5.1 Build 2600 Service Pack 3
    Processor type: Pentium PC
    Physical Memory: 3071 MBytes; Virtual Memory: 2699 MBytes
    User name: uzivatel
    Application info: Fleming_Release_R22530
    ________ Processes Currently Running ___________________________________
    ________ WindowList ____________________________________________________
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
    Anybody can help me?
    Intel Core 2 Quad Q6700 2,66 GHz, 8 GB RAM,NVIDIA Quadro K5200, 4 TB for video (2 TB in Raid), Win7ProCZ, MC 7.0.7 DONGLE Matrox MXO2 mini + second system... [view my complete system specs]
  • Sat, Oct 6 2012 3:56 PM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    Re: Cannnot export or videomixdown AMA sequence
    I also tried open bin in other project with the same end.
  • Sat, Oct 6 2012 5:26 PM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    I found solution - I transcoded AMA sequence to SD PAL 25i resolution.
    But I don´t know why videomixdown and export same as source don´t work Sad
