Latest post Thu, Nov 1 2012 11:05 AM by Larry Rubin. 84 replies.
Page 6 of 6 (85 items) « First ... < Previous 2 3 4 5 6
  • Tue, Oct 9 2012 9:46 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: MC 6.5.0/SN 6.5.0 NOW AVAILABLE
    magus:
    Has anyone installed MC 6.5 with Matrox MXO mini and running stable?
    Which drivers did you use?
    thx
    m
    The 6 ... 100 drivers that are certified for 6,03 will work also with 6,5 , stable if you don´t use the toggle off function, that goes also for 6,03
    Tomas
  • Tue, Oct 16 2012 8:21 PM In reply to
    • tonej
    • Joined on Mon, Jul 5 2010
    • Canada
    • Posts 4
    • Points 50
    Has anyone been able to get the Audio Punch-in tool to work with Matrox Mx02 in either MC 6.0 or 6.5?
    thx
    MC 5.0.4.4 / Asus P8Z77-V-PRO / Intel i7 3770 ivy bridge CPU / 32GB ddr3 1600 ram / Quadro FX 1800 driver ver 259.77/ Adrenaline w DNXcel also have Matrox... [view my complete system specs]
  • Tue, Oct 16 2012 8:45 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,173
    • Points 14,515
    It now works for me again in 6.0.3. Phew
    Symphony 2018.12.10, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99-A Mobo, i7 5820K 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 array @ 450Mbs
  • Wed, Oct 17 2012 2:12 AM In reply to
    • tonej
    • Canada
    • Posts 4
    • Points 50
    Hey Diesele, did you do anything special to get it to work? I downloaded MC 6.5 trial and when I click on the input source button "Matrox" is there but greyed out. Are you using the matrox 7.0.2 drivers?
    Cheers
  • Wed, Oct 17 2012 6:25 PM In reply to
    • DIESELE
    • Posts 1,173
    • Points 14,515
    I use an USB mic which has never worked in 6 (unlike 5).  I can now diasble the MX02 LE via the button and select windows mixer input as a punch in source.
    Be sure to disable the VT control, select only audio (no vision) , give it a 'tape' name too.
  • Fri, Oct 19 2012 1:56 AM In reply to
    • tonej
    • Canada
    • Posts 4
    • Points 50
    Thanks Diesele
  • Thu, Nov 1 2012 1:18 AM In reply to
    Hi !
    I would like to know if I can install MC.6.5 UPGRADE  without MC6.0 do I have to install it over MC6.0.
    Thanks a lot
  • Thu, Nov 1 2012 1:22 AM In reply to
    mark_brazil:
    First of all, every Avid software version is an entity unto itself. Except for patch files, you will NEVER install one version of MC over top of another one. So you would do a clean install of 6.5, which by the way, is a paid upgrade.
  • Thu, Nov 1 2012 1:44 AM In reply to
    Sorry but I new avid user anda I need your help to clarify some doubts.
    Ok I understood, But I have a doubt regarding a problem here , so far I did not install MC.6.0 UPG( always an error appear) and I want update the software , so I ask if you know what procedures step by step to install the upgrade of MC6.0 to MC6.5.
    obs. I installed MC6.5 trial and It works fine and I want I am afraid to use a version that has bugs yet.
    I have a new PC 64bits.
    I have the serial of MC 6.0 UPG, but my system ID belonged to MC5.5 and I´d like to know if MC6.5 generated onde for me, or itps not necessary anymore.
    Thank you vey much
    Marco
  • Thu, Nov 1 2012 11:05 AM In reply to
    Marco:
    Once again, if you want to upgrade from 6.0 to 6.5, you MUST PURCHASE IT. This is NOT a free upgrade. The serial number you have for 6.0 will not work with 6.5.
