Latest post Thu, Aug 23 2012 2:14 PM by maryd. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Aug 10 2012 4:12 PM
    • dnx
    • Joined on Fri, Aug 10 2012
    • Posts 1
    • Points 15
    Dekocast 4.1.2 XML/BCI Command List
    i'm working in third party application and would like to communicate with a dekocast 4.1.2 in TCP with XML Command.
    However, where can i find the complete list of XML?
    Thank you,
    Kind  Regards.
    Filed under: , , ,
  • Thu, Aug 23 2012 2:14 PM In reply to
    • maryd
    • Joined on Wed, Aug 23 2006
    • Posts 12
    • Points 1,895
    • Moderator: Avid Motion Graphics
    Re: Dekocast 4.1.2 XML/BCI Command List
    In the User's Guide XML Configuration section I see this info:
    XML commands and output are included in
    the DekoCast message log file.
    And
    The DekoCast log files are located in the same directory as the application
    You may be able to find the info you need there.
    You can also write a plug-in on DekoCast to perform functions.  There is a guide to creating plug-ins.  I could not locate it on Avid.com, but if you contact Customer Support they can guide you to it.
