Latest post Fri, Jul 27 2012 12:12 AM by mar/cus. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Jul 26 2012 5:53 PM
    • mar/cus
    • Joined on Mon, Nov 7 2011
    • sweden
    • Posts 102
    • Points 1,420
    Setting the media creation right
    Got some footage I now need to start edit, but I am not quit sure what resolution I should set in the media creation settings.
    I created a 1080p29.27 project, even though the footage is in 720p I wan't it full res so my text objects look sharp.
    My option for resolution are 45, 145, 220 and 220x. When using "media inspector" (an app for getting media info) it says 24.9 Mbps in Total Stream BitRate.. does that mean I can set my MCreation to DNxHD 45 and I wont loose any quality when I import them?
    thanks,
    marcus
    MacPro 2013 Quad-Core - Dual AMD FirePro D300 - 32GB Memory, PROMISE Pegasus2 R6 18 TB, Blackmagic Ultrastudio Express, Avid Omni HD Native, Artist Mix... [view my complete system specs]
  • Thu, Jul 26 2012 6:07 PM In reply to
    Re: Setting the media creation right
    Marcus:
    I would suggest that you take a small test file, perhaps 10 to 15 seconds long, and import it 3 times each at 45, 145, and 220. Then, compare them and see which is the lowest one that gives you what you would consider "lossless" quality. To help you estimate how much total disk space you will need at what resolution, here is a storage calculator tool.
  • Thu, Jul 26 2012 6:08 PM In reply to
    The footage could be long GOP and a low datarate so comparrison wth a frame based codec just doesn't work.
  • Thu, Jul 26 2012 7:22 PM In reply to
    • mar/cus
    • sweden
    • Posts 102
    • Points 1,420
    Larry Rubin:
    Marcus:
    I did a test, and couldn't see any major quality losses when using at least 145 as res, can see some in 45 though.
    My only problem is that the footage gets (slightly) darker blacks after importing, and/but lighter blacks after AMA/transcode than the original media. Why is this?
  • Thu, Jul 26 2012 7:25 PM In reply to
    marcus:
    Check your color space settings under the options tab in the import tool (RGB vs 601/709).
  • Thu, Jul 26 2012 7:41 PM In reply to
    • mar/cus
    • sweden
    • Posts 102
    • Points 1,420
    Larry Rubin:
    marcus:
    If you mean the tab "Image" in the import settings, the File Pixel to Video Mapping is set to "601 SD or 709 HD (16-235)".
    My project is set to YCbCr 709, my footage is in YUV (it says in media inspector).. is that right?
  • Thu, Jul 26 2012 8:49 PM In reply to
    Do you have color bars on any of the files you are importing? With those when looking at the waveforms, you can clearly see the difference between RBG mapping vs. 601/709 mapping to set the right choice. What is your project format? Does it match the format the footage was created in?
  • Thu, Jul 26 2012 8:59 PM In reply to
    • mar/cus
    • sweden
    • Posts 102
    • Points 1,420
    Larry Rubin:
    There is no color bars unfortunately.
    My project format is 1080p/29.97, YCbCr 709.
    The footage is recorded in MPEG-4 (codec AVC), 1280x720 progressive 29.97fps, color space YUV.
  • Thu, Jul 26 2012 9:29 PM In reply to
    It looks like you have things pretty well matched up, but what do you get if under the format tab, you change the color space option from YCbCr 709 to RGB 709 and do a test import?
  • Fri, Jul 27 2012 12:12 AM In reply to
    • mar/cus
    • sweden
    • Posts 102
    • Points 1,420
    Larry Rubin:
    Too high blacks again.
