Latest post Thu, Jun 14 2012 6:02 PM by Angelia. 4 replies.
  • Wed, Jun 13 2012 7:17 PM
    • Angelia
    • Joined on Wed, Jun 13 2012
    • Posts 3
    • Points 35
    Output settings from After Effects for DEKO 3000
    I am a motion graphics designer and I am animating lower thirds for use in a live broadcast on the DEKO 3000.
    I need know the best render settings to use for output from After Effects.
    Searching the boards, this is what I've found.
    59.94 fps
    .MOV file
    16 bit
    Animation Codec
    Best Quality
    RGB + Alpha
    Millions of Colors+
    Include audio track even if there is no audio
    This is how I typically output lower thirds that need a transparent BG.
    The main question I have is about matting and making sure the alpha channel works on the DEKO.
    Premultiplied? Straight (unmatted)?
    Can the BG simply be transparent or does it need a color (green) to key out?
    What's the most widely used solution for this?
  • Thu, Jun 14 2012 11:38 AM In reply to
    • maryd
    • Joined on Wed, Aug 23 2006
    • Posts 12
    • Points 1,895
    • Moderator: Avid Motion Graphics
    Re: Output settings from After Effects for DEKO 3000
    Here you go:
    59.94 fps Match the frame rate you are using in house.
    .MOV file  Correct
    16 bit      32 bit for alpha  24 bit for video only
    Animation Codec   Correct
    Best Quality    Correct
    RGB + Alpha   Correct for alpha
    Millions of Colors+   Correct for alpha, just Millions of Colors for video only
    Include audio track even if there is no audio  Correct, must be 48kHz
     This is how I typically output lower thirds that need a transparent BG.  Above settings will do this
    The main question I have is about matting and making sure the alpha channel works on the DEKO.  When the .mov file is imported to Deko it will be automatically split into 2 channels, one for video and one for alpha.  The import process will create the 2 files and link them on the Clip Editor
    Premultiplied? Straight (unmatted)?  Premultiplied
    Can the BG simply be transparent or does it need a color (green) to key out?  Normally transparent.
    What's the most widely used solution for this?  These settings are the most widely used
    I recommend doing a short test animation, having it imported into Deko and be sure all is working correctly.
  • Thu, Jun 14 2012 5:20 PM In reply to
    • Angelia
    • Posts 3
    • Points 35
    Thank you so much Mary!  I'd like to test it, however we are renting the HD truck and will only have it the day of the broadcast. Hopefully I'll be able to get in touch with the operator today and double check with her.
    Also, if the broadcast is 720p and the graphics are created at 1080p, will the Deko resize them, or should I go ahead and scale them down to 720p?
    Thanks Again.
  • Thu, Jun 14 2012 5:56 PM In reply to
    • maryd
    • Posts 12
    • Points 1,895
    Great question, sorry I did not verify - clips (animations on Deko) MUST be rendered to the same resolution that the Deko will be running.  So you should find out if they will set to run 1080i or 720p.  If you can't find out you should render them at both resolutions.
  • Thu, Jun 14 2012 6:02 PM In reply to
    • Angelia
    • Posts 3
    • Points 35
