Latest post Fri, Jun 15 2012 12:00 AM by bmedia. 2 replies.
  • Wed, Jun 13 2012 5:38 PM
    • TOPDOG
    • Joined on Tue, Mar 30 2010
    • Posts 81
    • Points 1,105
    Analog MOJO and AVID 3.5 Need an output to client monitor.
    Can the Analog MOJO and AVID 3.5 output an down conververted image if I'm editing in HD?
  • Wed, Jun 13 2012 5:51 PM In reply to
    Re: Analog MOJO and AVID 3.5 Need an output to client monitor.
    Did you try?  If so, what were the results?  Either way, you'll probably get a better image by buying a few 1920x1080 monitors, detaching the Mojo and just playing back full screen.
    Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Fri, Jun 15 2012 12:00 AM In reply to
    • bmedia
    • Princeton, NJ
    • Posts 99
    • Points 1,185
    I'm not using my mojo anymore but I'm pretty sure it can't. But it will output a signal to the monitor if you switch the project format to 30i. You can still edit HD footage in a 30i project, then switch it back to HD when you don't need the mojo output anymore. (You'll want to make sure the format is set to HD when rendering or importing, or that media will be DV.) If I recall, the downconverted image is going to look pretty soft.
    HP ZBook Studio x360 G5 / 2.7 GHz Intel Xeon E2176M / NVIDIA Quadro P1000 / 16GB RAM / WIN10 Pro / MC 2019.9 [view my complete system specs]
