Latest post Thu, Jun 14 2012 10:36 AM by Job ter Burg. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jun 13 2012 2:47 PM
    • tacbob
    • Joined on Tue, Jul 12 2011
    • Posts 73
    • Points 1,060
    Import P2> Clips to Bin or Link to AMA?
    What is the most efficient workflow - Import Clips to Bin or Link to AMA?
    When I have imported P2>Clips to Bin i have been told to Consolidate the files which duplicates the media, filling up hard drive space which I don't want.
    What is the difference between linking to AMA and just importP2 Clips to Bin without consolidating?
    Filed under: , , ,
  • Wed, Jun 13 2012 3:52 PM In reply to
    Re: Import P2> Clips to Bin or Link to AMA?
    Not much. As far as I can tell, File->Import P2 is an early implementation of what later became AMA.
    That said, I would not worry about the drive space and consolidate. It is more flexible and often much faster to turn everything into Avid media files.
  • Wed, Jun 13 2012 4:11 PM In reply to
    Job ter Burg:
    And in the case of longer and more layer/effects intensive timelines, far more stable.
  • Wed, Jun 13 2012 9:35 PM In reply to
    • tacbob
    • Posts 73
    • Points 1,060
    Thanks people!
    So I guess you are saying stick with Import P2 and then consolidate/import media.
    Do you still consolidate if you link to AMA?
    When I have consolidated and my computer is full up with the Avid files, can I then remove the original files that I copied over?
  • Wed, Jun 13 2012 11:10 PM In reply to
    tacbob:
    I would, yes. Working woth AMA-linked files to me makes no sense on anything you work on for more than a day.
    I would never delete originals, ever. But if they are copies of the camera original, then there is no need to keep them. Consolidate will preserve native quality and metadata.
  • Thu, Jun 14 2012 9:48 AM In reply to
    • tacbob
    • Posts 73
    • Points 1,060
    Thanks. It would not be the originals I would delete, just copies of them.
    But , eventually I would need to copy the Avid Media Files onto an external drive/server to clean up the computer. If I need to reopen a project and I had taken the Avid Media Files off/copied onto a hard drive/server, do I just copy them back into the Avid Media Files folder?
    Can I ask, what is the difference between these files - the original P2/mxf and the new Avid Media Files?
  • Thu, Jun 14 2012 10:36 AM In reply to
    tacbob:
    Yes.
    tacbob:
    I think they have slightly different metadata layouts (and Avid files have more metadata), but I can't say for sure.
    There used to be a method (in the early days of P2) where folks would drag the original MXF files into the Avid MediaFiles folders, but I think that did prove to be problematic. Don't know the tech details.
