Latest post Sat, Jun 2 2012 4:12 AM by R. 4 replies.
  • Sat, Jun 2 2012 1:08 AM
    • R
    • Toronto
    • Posts 76
    • Points 1,095
    Export of QT Ref - Codec problem...
    I'm having problems with the exporting of QT Reference files in Avid MC6.  The audio is fine, but the video is white when I bring it into Sorenson Squeeze.  I tried re-installing the AvidCodecsLE2.1 codecs... not change.  I'm running QT 7.71.  Not sure what else I'm suppose to do.  I'm assuming it's a codec issue...
    Any help would be appriciated,
    -Richard
    HP Z420 Workstation | Intel Xeon CPU E5-1620 @ 3.60 GHZ 3.60 GHz | Thunderbolt 2 Upgrade | 32 Gigs of RAM | NVIDIA® Quadro® P2000 | Windows 10 Pro 64... [view my complete system specs]
  • Sat, Jun 2 2012 1:31 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,861
    • Points 24,395
    Re: Export of QT Ref - Codec problem...
    What format were the original files in?  How were they brought into MC?  Also please post your complete system specs.
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Sat, Jun 2 2012 1:57 AM In reply to
    • R
    • Toronto
    • Posts 76
    • Points 1,095
    Media Composer 6.0.1 (PC) | Intel 2 Quad 2.4 Ghz Q6660 | 8 Gigs of RAM | Nvidia Quadro FX4800 | Driver 259.77 |Windows 7 Professional 64bit | Duel HP ZR2440W Monitors |
    Footage was shot on EX CAM and converted to MXF file format using XDCAM EX Clipbrowser.  I imported those files...
    I was running MC5.5 last week and was exporting QT Ref files to Sorenson 7.  Had no problems.  Now with the upgrade to MC6 and SS8.0, I'm having these issues.
  • Sat, Jun 2 2012 3:35 AM In reply to
    • taloftus
    • SF, CA USA
    • Posts 50
    • Points 675
    The white screen is a giveaway for a missing qt codec.  I can't exactly recall if ex is the same, but with xdcam, if you export a qt ref from avic using native resolution, you cannot play the video.  You need to buy the calibrated software xdcam quicktime codec (http://www.calibratedsoftware.com/QXD.asp).  The white frame your are seeing means you don't have the codec installed.
    If you do a video mixdown, or transcode the footage to dnxhd, you don't have the codec problem.
    Now as to how you were able to export with no problems using 5.5... no ideas.
    Good luck.
    MC 8.3. Mojo DX, HP xw8600, Win 7 64, 16 GB Ram, Nvidia Quadro FX 3700 [view my complete system specs]
  • Sat, Jun 2 2012 4:12 AM In reply to
    • R
    • Toronto
    • Posts 76
    • Points 1,095
    Yeah you're right.  That installation of the codec worked.  Thanks for your help!
    When I was talking about using MC5.5 to export files, the footage wasn't XDCAM. :)
