Latest post Wed, Jul 26 2017 1:30 AM by bobcat. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Wed, Jun 6 2012 6:46 AM In reply to
    Re: Canon 5D Mark iii
    souzpalooz:
    Does the 5D Mark iii Span clips like p2 media or does it make indiviual quicktimes? If it does span clips what do you have to do to link all the mov files to make them 1 video file in avid?
    It never spanned clips before hence the limited shot record time.
    This due it reaching max file size due to card format.
    however not being able to span clips makes tapeless workflows easier !
  • Wed, Jun 6 2012 5:09 PM In reply to
    • souzpalooz
    • Joined on Sun, Jun 3 2012
    • Posts 6
    • Points 105
    Working in reality TV Spanned clips are good because we leave the camera running for 40 min at a time. When making groups you dont want to have breaks for no reason. So is the awnser no? We can not make this .mov files span into 1 clip in the avid?
  • Wed, Jun 6 2012 5:22 PM In reply to
    souzpalooz:
    The issue is the camera isn't a tapeless camera it records until it's reached maximum file size and then stops and you have to restart the recording on the camera. It's the camera that isn't doing the spanning.
    It's shame you can't feed timecode into the camera otherwise you could have more than one camera and start with a time offset just like we used to do with 20minute limited tape formats then as each camera stopped and a tape was changed the other would be mid record length. Ensuring one camera at least was recording all the time.
  • Wed, Jun 6 2012 5:32 PM In reply to
    • souzpalooz
    • Posts 6
    • Points 105
    We are talking about the Canon 5D Mark iii, This does do spanned clips. You can record 40 minutes straight without stopping the camera. this would make about 4 10 mintue .mov files are 4gb in capacity. This camera also records timecode, but just time of day (or whatever you set). but You are right about not sending it timecode from an external source.
  • Thu, Jun 7 2012 7:29 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,805
    I have the camera and although I have not tested it, my understanding (from the manual) is that it records 29min 59sec to get around some EU tax law . . . ?
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Thu, Jun 7 2012 7:42 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    souzpalooz:
    Have you tried to link to volume, it needs to be the origin untouched folder structure
    Tomas
  • Fri, Nov 22 2013 3:38 PM In reply to
    We just experienced this as well. We shot a series of long interviews. The camera DOES create a kind of span clip in that, when it reaches max file size (at around 10 minutes apparently(, it will automatically and seamlessly create a second video file so that if you lined the two up in a timeline they would match up exactly.  However unlike P2 or XDCAM, AMA will not identify those separate media files as one continuous clip. It treats each one as its own distinct clip.  Which made this multi-camera edit a nightmare to group.  I imagine it works this way because the 5D doesn't appear to create any kind of metadata table that I can see?
  • Fri, Mar 14 2014 1:09 PM In reply to
    • spejampar
    • Joined on Mon, Mar 3 2008
    • Evanston, IL
    • Posts 38
    • Points 460
    yes, I would like to know the best way to deal with canon 5d mk iii spanned clips in a multicam workflow.  The easiest thing I came up with was putting them in a sequence and making a mixdown.  Definitely not ideal if you need TC but it's not a horrible workaround.  I just can't believe there isn't a better way.  Hopefully an update to AMA will come soon so it will automatically combine those clips into one.
  • Mon, Jul 24 2017 10:06 AM In reply to
    • loki
    • Joined on Sat, Mar 17 2012
    • Posts 27
    • Points 345
    Since I am stuck in the same "long interview, multiple multigroups, audio tc"-workflow right now I wanted to ask if anyone came up with a better approach?
    I know there is some self programmed software to combine the footage before loading them into MC but I cannot find it anywhere. EOS movie utility does not recognize 5D mk iii clips unfortunately.
    Anyone has a better workaround?
    Cheers,
    Max
    MC 8.8.4 OSX 10.12.4 MacPro 6,1 [view my complete system specs]
  • Wed, Jul 26 2017 1:30 AM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • Southwest, USA
    • Posts 522
    • Points 6,075
     EditReady 2
    Used to be called Clipwrap. Should do the trick.
    Avid MC 6.5.2.1 with 27"iMac 2.8GHz Intel i7 OSX 10.8.3, 12GB memory, ATi Radeon HD 4850, Caldigit Raid [view my complete system specs]
