Latest post Mon, Sep 24 2012 2:09 PM by ErinC. 45 replies.
Page 3 of 4 (46 items) < Previous 1 2 3 4 Next >
  • Thu, May 3 2012 8:49 AM In reply to
    Re: How do I record using USB mic from scratch?
    Alright guys...thank you all for your time and input.
    This method "should" work...but it's not.  I've opened a new project, NO cam, and flipped the settings to mimic Douglas' screenshot...nada.
    Anyway, I believe in putting a round peg in a round hole and using appropriate software when needed.  I was hoping MC was an all in one solution.
    However, out of the recent replies, Adobe Audition popped up, and this is what I currently use for other audio editing.  It'll probably be the path that I'll use to capture from the mic.  I can do stuff like noise reduction, etc within this program, export to wav and MC import.
    Phew!!
    Aloha from Hawaii,
    Irwin
    AVID Media Composer 8.5.1 / Windows 10 Pro 64-bit / Intel i9-9900K 3.6ghz, 32gb RAM, AMD Radeon Pro WX7100, 1TB SSD (OS & App only), Highpoint RAID... [view my complete system specs]
  • Thu, May 3 2012 9:01 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,385
    irwinpks:
    Irwin, you are a little out of specs, you of course know that, just telling, might be a reason to why it works for others, just a thought .
    Tomas
  • Thu, May 3 2012 9:27 AM In reply to
    mjolnarn:
    irwinpks:
    You mean hardware specs? I believe it's all covered and surpasses what is here for the PC:
    http://www.avid.com/US/products/Media-Composer/system-requirements
    BTW, I've added another 4gb for a total of 8gb in the system.
    I'm suspecting the following:
    - Setting in MC (the USB mic works with the audio punch-in tool)
    - Conflict with the headset Mic that I have
    - Conflict with another USB device
    - Conflict with other installed software
    I'm hoping that it is simply a setting that I haven't executed.
    Here are my alternate solutions:
    - Temporarily add a graphic and extend the time on the timeline to fit my microphone recording sequence and then use the Audio Punch-in Tool
    - Use Adobe Audtion to record from the microphone.
  • Thu, May 3 2012 9:33 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    irwinpks:
    Specs or not, this above would be my first guess, if you have 2 different external mics connected at the same time . that might be what´s causing this
    Tomas
  • Thu, May 3 2012 9:42 AM In reply to
    mjolnarn:
    irwinpks:
    Logically, if the USB Mic works with the Audio Punch-in tool, you'd think that it should transpose easily to the Capture Tool.  But before you posted, I disconnected the headset mic which attaches to the audio input jack on the soundcard.  So, that added mic is not the problem and eliminated from the list as a cause.
  • Thu, May 3 2012 9:51 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    As I got curious and felt for testing myself , I have just done that using my XFi Elite Pro soundcard with a 600 dollar headset attached , worked like a charm so that makes one more of us having this working now .
    Tomas
  • Thu, May 3 2012 9:59 AM In reply to
    mjolnarn:
    Bah...I'm jealous! Hmm
  • Thu, May 3 2012 10:13 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    For everyones knowledge wanting to test, this doesn´t seem to be possible with a Matrox unit attached, maybe also other external hardware have the same behaviour
    Tomas
  • Thu, May 3 2012 1:14 PM In reply to
    irwinpks:
    on page 1, I wrote:
    You can just about record scratch audio into anything and export a .wav that you then import into Avid.  Avid is not going to recognize a USB mic as a capture device, so you will have to use another app.
    irwinpks:
    Uh...you lost me at the explanation of "scratch" Hmm
    You asked how to record using USB from scratch.  You meant to ask how to record using USB for scratch.  I was facetiously pointing out the different meaning of your question depending on which preposition you use.
  • Thu, May 3 2012 1:26 PM In reply to
    • Posts 11,528
    • Points 235,090
    Kenton.VanNatten:
    Kenton,
    Did you take a look at the video I posted the link to?
    I am using a USB mic in the video, as a capture device in MC through the Capture tool.
    Regards,
    Douglas
    VIDEO IS HERE
  • Thu, May 3 2012 1:32 PM In reply to
    Things must've changed recently then, because for as long as I remember you couldn't use any USB connected devices for capturing with Avid.
  • Thu, May 3 2012 1:38 PM In reply to
    • Posts 11,528
    • Points 235,090
    Kenton.VanNatten:
    I am pretty sure that you are correct,Kenton
    I was surprised when I tried and it worked.
    I guess that's progress for you
    Regards
    Douglas
  • Thu, May 3 2012 3:31 PM In reply to
    • adam5000
    • Posts 643
    • Points 8,525
    Its worked in MC on the mac side for a while, not sure how long but a couple of years at least.
    MC Version 8.4.4 Mac OS 10.10.5 IMac 27" 3.2 Ghz i5 16gb RAM [view my complete system specs]
  • Wed, May 9 2012 6:31 PM In reply to
    Just to jump in on this even though it is a few days old..
    To record from a USB device OUTSIDE of MC, which is what I think the OP was meaning when he said from scratch, you need a software app that will recognize ASIO type devices. A free piece of software that I use is called Krystal. Do a google on it and you should find it.
    There is also a small utility called ASIO4All that is needed I believe.
    Audacity is the audio editor I normally used by unless they changed it in version 2 which just came out, version 1.3 didn't see these types of devices, which is why I found Krystal.
    I have a small 4 channel USB mixer I use for streaming which allows me to use normal mics and the like.
    Good luck,
    Jeff
    MC5.0.4, Panasonic AG-AC130 HD Cam & DVC30 SD Cam, Sager 9170 laptop, 17" 1920x1080, i7 3rd gen, 8gb ram, dual Hd's, GTX675m graphics. Emachine... [view my complete system specs]
    Created Design Video - "Video for the common man"
  • Wed, May 9 2012 6:47 PM In reply to
    almost40_3girls:
    Good luck,
    Jeff
    Hi Jeff, the intent was to use MC as an all in one solution.  However, there are mixed results from different users, though in Douglas' situation...that's what I was going for.  Anyway, I've chosen to use Adobe Audition which is already part of my CS5 suite.  Once I've done my recording & audio editing there, the completed file will be imported into MC.
