Latest post Thu, Oct 6 2016 2:09 PM by mtahir. 17 replies.
  • Mon, Apr 30 2012 8:55 PM
    • mjedit
    • Joined on Mon, Feb 16 2009
    • Orkney
    • Posts 14
    • Points 180
    tearing fix - moncon off
    For those people who have had screen tearing problems, I can sympathise with you. My tearing happened in any video quality, both source and record, full screen, different monitors, trying different refresh rates on the monitors. I've spent days now trying to sort this. All the NVidia settings as per Avid Read Me, vertical sync on, triple buffering, tearingfix in the console command, NVidia support suggesting it might be a faulty graphics card, to running test after test, several versions of drivers, thread after thread. And then I came across this
    http://community.avid.com/forums/p/104741/606004.aspx#606004
    I typed - moncon off in the console command
    and bingo, no tearing, my footage looking how it should - elation
    Why, I don't know, as I didn't have the same problem as this was a solution for. But I'm not complaining!
    Please, can this command and a possible fix be high priority. I believe it hasn't been fixed in MC 6.01.1.
    Just to add, the image does still stutter in reverse motion, but I can live with that.
    One further thing which I've seen in a thread - I couldn't select enable video editing mode in the NVidia conrtol panel as suggested in the ReadMe file, as it was always grayed out. However, the route around this was to run control panel as administrator (even though I'm the only user, I since found out that I'm not actually administrator with FULL control).
    Hope this helps
    MC 6.0.1, Windows 7 Professional 64 Bit, MB - ASUS P6T Intel X58 Express Chipset, Processor - Intel Core i7 i7-920 2.66 GHz Quad core, RAM - Corsair DDR3... [view my complete system specs]
  • Fri, Sep 14 2012 9:45 AM In reply to
    • Chris
    • Joined on Fri, Oct 7 2011
    • Hamburg, Germany
    • Posts 12
    • Points 150
    Re: tearing fix - moncon off
    jesus! thank u so much. i was on the same journey as u, virtually reading every single thread about this issue, trying
    every suggested solution - no avail!
    but finally this one did it on symphony 6.0.3 : aaahhh!!!  Smile
    MacPro Dual Quadcore 2.8 GHz | 16GB Ram | Nvidea Geforce GTX 285 | Lion 10.7.5 | MacBook Pro Core i7 2,8 GHz | 16GB Ram | Mountain Lion 10.8.5 | Symphony... [view my complete system specs]
  • Fri, Sep 14 2012 10:54 AM In reply to
    • Radman
    • UK
    • Posts 911
    • Points 10,620
    Just hope there is no MONCON OFF from above! Sure will be some tearing.
    Win10 64Bit / HP Z800-XW8200 / 5x Quadro M6000. 48 Gig Ram / Cubix Expander 4 / 2x 32TB SAS JMR Raid unit / Avid Artist | Avid Artist DNxIO. 3x 27"... [view my complete system specs]
  • Tue, Mar 19 2013 2:48 PM In reply to
    Amazing!  Thank you moncon off!
    17" MBP, 2.3 GHz Intel Core i7 16 GB 1333 MHz DDR3 Mac OS X Lion 10.7.5 MC 6.0.1 [view my complete system specs]
  • Wed, Mar 20 2013 4:05 PM In reply to
    Adenumn:  MONCON OFF takes care of the tearing but now my fullscreen playback turns off randomly.  Anyone aware of the initial issue being address in newer versions?
  • Wed, Mar 20 2013 4:51 PM In reply to
    • mjedit
    • Orkney
    • Posts 14
    • Points 180
    I've not had a problem with FSP turning off randomly. Running same version MC 6.01. Sorry it didn't work out for you. It's an anomaly and not one that has been addressed as far as I can tell.
  • Thu, Jun 6 2013 5:16 PM In reply to
    • Nick
    • Joined on Tue, Apr 9 2013
    • Posts 18
    • Points 180
    "moncon off" didn't work with MBPr and MC 6.5. Anyone else come across a solution?
    Nick
    Macbook Pro, 2.6 GHz, i7, 16GB DDR3, 500GB SSD, NVIDIA GeForce GT 650M 1024MB [view my complete system specs]
  • Thu, Jun 6 2013 5:50 PM In reply to
    • Nick
    • Posts 18
    • Points 180
    Solution for MBP with Retina:
    In the "Settings" tab in Avid, go to "Full Screen Playback" and then check the "Flip on vertical Sync" Box.
  • Wed, Jul 17 2013 10:35 PM In reply to
    • cls105
    • los angeles
    • Posts 513
    • Points 6,590
    I am surprised that Avid has not chimed on this tearing issue.  I've tried serval things with no success, i'm always getting tearing.  I dislike hardware because it often creates minor sync delays (2 frames is too much for fast paced cutting).
    I've tried vertical sync, moncon, it different combinations to no avail.  What is the ideal refresh rate?  thanks
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Fri, Jul 19 2013 2:41 PM In reply to
    • mjedit
    • Orkney
    • Posts 14
    • Points 180
    I don't think refresh rate has anything to do with it. Interestingly, I've got two set ups now, both with LG monitors, both NVidia settings exactly the same (though they have different video cards and therefore drivers). My first set up, using moncon off, has no problems any more. The later set up has terrible tearing. The only solution here are 3 console commands: 'moncon off', 'fsp locked', 'tearingfix'. The first two have to be typed in at every reboot of Avid. The latter not. I have no full screen tearing until.... I fast forward or backwards. Don't ask me why. But the simple fix is to exit FSP and enter again. No tearing. Be interested to know if it works for you.
    There is so much written about this in the forums - I've spent days trying to find a true solution.
    These are the main threads I found useful:
    http://community.avid.com/forums/t/74412.aspx?PageIndex=1
    http://community.avid.com/forums/p/63436/412058.aspx#412058
    http://community.avid.com/forums/t/77967.aspx
    Doesn't seem to be any rationale at all. Afraid it's suck it and see.
    If you want to know my exact NVidia settings let me know and I can email you screen grabs.
  • Thu, Feb 13 2014 7:07 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 944
    • Points 11,060
    I'm working with MC 7.03, now and I still have to use the console command "moncon off" to get fullscreen work. Will this ever be fixed?
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Sat, Dec 5 2015 9:56 PM In reply to
    • GaryF
    • Joined on Mon, Jan 30 2012
    • Posts 78
    • Points 1,180
    Its a sell hardware by Avid thing. Avid wants you to get one of there nitris boxes or something. Black magic can be used as well
  • Sun, Dec 6 2015 8:44 AM In reply to
    • Marty
    • Berlin, Germany
    • Posts 944
    • Points 11,060
    It's strange, when I don't use "moncon off" the fullscreen picture shows me the low contrast legal range colors on a computer screen, although "expand luminance range..." is enabled and I get tearing artefacts.
    If I use "moncon off" the contrast is right but i can't play reverse, the software crashes more often, target masks are not working, i can't work with a reduced composer window. (MC 8.4.2)
    Really frustrating.
    www.film-editing.de
  • Mon, Dec 7 2015 5:01 AM In reply to
    • cls105
    • los angeles
    • Posts 513
    • Points 6,590
    windows 7 has tearing no matter what I did.
    windows 8.1 does not.
    That's how i solved tearing.
  • Mon, Dec 7 2015 2:55 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    I'm the one who posted the original MonCon Off work around, and as I said in that post it's a work around, not a fix. The original post was for getting around driver incompatibilties with unsupported Nvidia GTX cards and drivers, I never tested it with 3rd party hadrware I/O boxes.
    The only real solution is to get a supported Quadro (or AMD FirePro for the latest version). Other than that, I can tell you that for the GTX, driver 353.30 worsk with MC 8.4 and up on WIndows 8.1 Pro without a 3rd party I/O box. Depending on your system, you may have to upgrade or downgrade drivers, and there are some configurations that are incompatible in all cases.
    If you have a qualified video card, you should use the driver supplied with your version of MC (supplied in the MC directory) or one approved by Avid.
    Dave S.
