Latest post Sat, Apr 28 2012 6:32 PM by anglegrinderUK. 3 replies.
  • Wed, Apr 25 2012 11:36 AM
    Reversing a mixdown
    Done a silly thing. Mixed down loads of layers & forgot to make a unmixed down copy of sequence.
    I can step into the mixdown & adjust - but is there any way I can actually reverse the mixdown & create new sequence of the underlying layers?
    Apple iMac 27" 2.7GHz Intel Core i5, 12 GB 1333 MHz DDR3 memory O/S 10.10.5. Media Composer V8.4.5 [view my complete system specs]
  • Wed, Apr 25 2012 11:39 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Reversing a mixdown
    Nope, the attic might save you however
    Tomas
  • Wed, Apr 25 2012 8:05 PM In reply to
    • taloftus
    • SF, CA USA
    • Posts 50
    • Points 675
    If you can step into it, you may not have done a mixdown, rather you collapsed multiple tracks into one track.  Step in and mark in and out over the entire duration and select all tracks.  ALT+C (or the MAC equivalent -- I'm on a pc) copies all the selected tracks to your source monitor, then you can drag the sequence icon from your source monitor to a bin.  Voila, you now have a multi track sequence... you can then edit over the submastered/collapsed effect
    I would suggest making a copy before you try all this...
    If you did do a mixdown, and cannot step in and see the individual layers, then you attic will be your best bet.
    Good Luck!
    MC 8.3. Mojo DX, HP xw8600, Win 7 64, 16 GB Ram, Nvidia Quadro FX 3700 [view my complete system specs]
  • Sat, Apr 28 2012 6:32 PM In reply to
    Brilliant - many thanks
