Latest post Mon, Oct 7 2013 3:00 PM by BenoitM. 80 replies.
Page 1 of 6 (81 items) 1 2 3 4 5 Next > ... Last »
  • Sun, Mar 11 2012 8:30 PM
    Can't Enable Nvidia "Video Editing Mode"
    I'm in the process of installing MC 6.0.1 on a completely new computer. No Avid product has ever been installed on it. I've downloaded the Readme for 6.0.1 and have been working my way through it. Under "Setting up the NVIDIA Card" on page 24 it says to set Desktop to Video Editing Mode by:
    1. Right-click the Desktop, and select Nvidia Control Panel.
    2. In the menu bar, select Desktop. Enable Desktop>Video Editing Mode.
    3. Click Apply.
    But when I choose the Video Editing Mode, the check box does not activate and the Apply button does not appear. A search of this forum shows that at least two other users have had this problem, but I haven't been able to locate a solution.
    Again, this is a completely clean OS. MC hasn't even been installed yet. I'm first going through the Readme to set up the drivers and supporting programs properly.
    Thanks much for any help!! :)
  • Sun, Mar 11 2012 8:54 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Can't Enable Nvidia "Video Editing Mode"
    Is your videocard a certified one, the system specs tells nothing about that
    Tomas
  • Sun, Mar 11 2012 9:00 PM In reply to
    My bad, just wrote that out--will update. It's a Quadro 2000.
  • Sun, Mar 11 2012 9:04 PM In reply to
    • Ian Stockdale
    • Joined on Wed, Jun 3 2009
    • Plymouth U.K.
    • Posts 38
    • Points 470
    Off topic but how did you manage to spend so much on *Edit, surely that's a price tag for at that time 'inferior' Avid?  ;-) PS I can't enable desktop editing either!
    HPxw8400 workstation, Twin 3Ghz Xeons, 5G RAM, Win 7 pro 64 bit, NVidea Quadro FX1500, 2xWD500 3x Seagate Barracuda 1TB SATA's, Texas instruments OHCI... [view my complete system specs]
  • Sun, Mar 11 2012 9:09 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    BobbyMurcerFan:
    Ok, as you see from my specs I have the older version, worked well here, will go through all the steps one again, from memory it was somewhat picky, I had to have the description on one computer and setting it up on another really following all the descriptions line by line.
    Please tell if you manage to do it if you try one more time.
    Tomas
  • Sun, Mar 11 2012 10:16 PM In reply to
    I have never seen such a setting nor enable it.
    What it does?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Mon, Mar 12 2012 12:51 AM In reply to
    • Radman
    • UK
    • Posts 911
    • Points 10,620
    Bobby,
    Strangley I am having the same issue on new z800.
    I have a Quadro 2000D plus Quadro 5000.
    On my xw8200 had a monitor attached to each. Could always select EDITING mode.
    Now, in the z800 I have both monitors attached to the Quadro 2000D and use the Quadro 5000 in my Cubix expander for rendering. Works more than great, but no EDITING mode? Just noticed today.
    Also my BMD Multibridge Eclipse is now working like a ROCKET. Will do another thread on my experience. Bandwidth, that the issue!
    Radman.
    Win10 64Bit / HP Z800-XW8200 / 5x Quadro M6000. 48 Gig Ram / Cubix Expander 4 / 2x 32TB SAS JMR Raid unit / Avid Artist | Avid Artist DNxIO. 3x 27"... [view my complete system specs]
  • Mon, Mar 12 2012 7:00 AM In reply to
    Thomas and Radman,
    I haven't been able to get it to work. I've search Google, the Nvidia Control Panel Help and Nvidia's knowledge base. I really can't find out much about the usefulness of this setting.
    George,
    I've attached a picture of what the setting look like.
    P.S. It's interesting that when I first try to enable this setting, the screen goes blank for a second or two as if it's trying to set something but then quits. If I try enabling the setting again (w/o rebooting) this black flash does not happen. But either way, Enable Video Editing Mode remains unchecked.
  • Mon, Mar 12 2012 7:49 AM In reply to
    • Radman
    • UK
    • Posts 911
    • Points 10,620
    Hi Bobby,
    As I mentioned, it does not seem to be affecting anything with my graphics and Avid MC6 at face value. Would be interesting to find out the answer though.
    Avid also seems to be using the Quadro 5000 for rendering with no issues.
    The combination seems perfect.
    Cheers
    Radman.
  • Mon, Mar 12 2012 8:09 AM In reply to
    Radman,
    I'm going to continue w/ the install, and I believe MC will work with this setting not enabled. But I'm a little concerned for two reasons.
    First, it's mentioned in the Readme to do this... and it can't be done, AFAICT. Second, it's very difficult to tell how much help a setting like this might provide. So while MC seems to work fine w/o it, does it work even better w/ it turned on?
    Thanks very much for your input Wink
  • Mon, Mar 12 2012 8:32 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    From what I have seen this mostly affects systems with any type of external hardware connected as for example a Matrox unit.
    This can also be the reason to why some users have less good behaviour together with the external units.
    Tomas
  • Mon, Mar 12 2012 8:56 AM In reply to
    Thomas, were you able to activate Enable Video Editing Mode on your system? Thanks much.
  • Mon, Mar 12 2012 9:30 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Yes, was a while ago and as I said it was a line to line read but it worked well.
    Tomas
  • Mon, Mar 12 2012 1:22 PM In reply to
    Have a Quadro 4000 in the Z400, and a Quadro 1800m in the laptop and was able to check "Video Editing Mode" on both. All I can think of is that I did it AFTER installing MC. Also have PP5 on both machines for what ever that is worth.
    System 1: HP Z400, 3.20G Quad Core, Quadro 4000, 250G SSD system drive,Windows 7 64, MojoDX w/active hib, 6G ram, Cal Digit VR ESATA Raid, Recommended... [view my complete system specs]
  • Mon, Mar 12 2012 1:35 PM In reply to
    • ozzob
    • Joined on Mon, Aug 23 2010
    • Posts 89
    • Points 1,180
    I can't enable it either. After re-installing things in various orders I gave up. MC always recognizes the Quadro 2000 card and things seem to work. It is a mystery.
    MC latest w/Symphony | 416.34 video driver | Quicktime 7.7.9 | Boris CC 2019 | Squeeze Pro 11 | Sony DVD Architect Pro 6.0 | Windows 10/64 Professional... [view my complete system specs]
