Latest post Thu, Mar 8 2012 1:30 AM by Dom Q. Silverio. 2 replies.
  • Wed, Mar 7 2012 10:04 AM
    • mkj
    • Sweden
    • Posts 454
    • Points 5,995
    is there any guide how to set up ISIS clients with [ethernet] - [fibre] - [ethernet]?
    -or do anyone here have some experiense of this?
    -we need to have some clientes around 150 m away from the ISIS...and the maximum lenght of cat6 cables is 100 m..so we would like to extend with fibre
    would be very thanful if someone can help me with this!
    BR
  • Thu, Mar 8 2012 12:42 AM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 140
    • Points 1,570
    Re: is there any guide how to set up ISIS clients with [ethernet] - [fibre] - [ethernet]?
    multiple ways.
    1. GigaBit Ethernet/Fibre Channel Transceiver
    2. Add a another switch into the equation, preferably one that can uplink to the iSIS switch at 10-Gbit. ( This will put the clients on the new switch in Zone3 )
    6 ISIS5000 split in two environments, 25 MC7+SYM NitrisDX, MacPro3,1 MacPro4,1 [view my complete system specs]
    Ted Simbajon
    http://www.tedsimbajon.com
    Head Janitor
  • Thu, Mar 8 2012 1:30 AM In reply to
    The default switch that comes with the ISIS 5000 has 4 optical ethernet ports (last 4 ports). You just need to buy SFPs for the port and the Intel 1000 PF card (or Small Tree on Macs) for the clients. Standard 850nm multimode cable is used. (LC-LC).
    If you need more than 4 clients, then you would need the optical version of the Force10 switch.
    Remember though you are using fiber, the data transmitted still follows gigabit protocols, thus 1 Gb/s IP based.
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
