Latest post Thu, Apr 19 2012 3:43 AM by Mondo. 32 replies.
Page 1 of 3 (33 items) 1 2 3 Next >
  • Wed, Feb 22 2012 8:44 PM
    • Ian Stockdale
    • Joined on Wed, Jun 3 2009
    • Plymouth U.K.
    • Posts 38
    • Points 470
    MC 6 & 6.01 freezes and white screens.
    Clean install of win7 pro 64 MC 6.01 and all the attendant drivers.  With the recommended nvidea driver I get BSOD as MC loads it's viewer panes.  The BSOD names the nvidea driver as the culprit.  If I install the latest nvidea rather than the previous I get random white screens.
    Everything has been installed, uninstalled and reinstalled with the same results every time.  Ideas gratefully received.
    HPxw8400 workstation, Twin 3Ghz Xeons, 5G RAM, Win 7 pro 64 bit, NVidea Quadro FX1500, 2xWD500 3x Seagate Barracuda 1TB SATA's, Texas instruments OHCI... [view my complete system specs]
  • Wed, Feb 22 2012 8:54 PM In reply to
    Re: MC 6 & 6.01 freezes and white screens.
    Have you tried to Turn Off the Threaded Optimization
    in 3D Settings of Nvidia's panel?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Feb 22 2012 9:19 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    No but I'll have a look tomorrow, thanks for the tip!
  • Wed, Feb 22 2012 9:24 PM In reply to
    • Posts 11,262
    • Points 231,870
    Hello Ian,
    I believe that the NVidia Quadro cards with an x500 number can have issues with the newer drivers in combination with MC6.
    I have an Nvidia Quadro 3500 and another machine with an Nvidia Quadro 3700 card. The 3700 runs well with the supplied drivers, but the 3500 crashes.
    I rolled back to the 190.38 drivers for the 3500 card and all works well there too.
    Try installing the 190.38 drivers.
    REgards,
    Douglas
  • Wed, Feb 22 2012 9:28 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    Thank you, I'll try that too.
  • Wed, Feb 22 2012 9:29 PM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    I have also been fighting this problem.  the system is a T5400, FX3600 and a nitris dx.  It works ok without the nitris connected but when connected, randomly it locks up when you press play - white screen etc.
    This setup worked perfectly on ver 4 and 5 - what has changed in 6?
    Tried everything.  new drivers, old drivers, complete reinstall of OS and Avid.
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Wed, Feb 22 2012 9:31 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    That's my story exactly!
  • Wed, Feb 22 2012 9:34 PM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    I can only think that Avid have made a software error with this config.  This is a fully qualified system so why doesnt it work!
  • Wed, Feb 22 2012 9:40 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    If you use nvidea 275.89 do you get BSOD?
  • Wed, Feb 22 2012 9:54 PM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    I did have a BSOD problem with an FX1400 and ver 190 driver but the later driver sorted that.  So with the 275 driver and the FX3600 - no I did not have the BSOD.
    I am at a loss with this one.  I tried two different graphics cards so it cant be the card or driver.  I was thinking it was a dell problem but you are on an HP......
  • Wed, Feb 22 2012 10:01 PM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    Have you seen this from an old post?:
    "I managed to replicate the problem, establish a pattern and come up with a workaround. Hopefully, this will give enough hint to the mighty engineering team in Burlington to fix it. So here it goes:
    -if project is launched with no BOB attached, system works fine
    -if project is launched with MojoDX attached in green-green 8/10bit modes, system will not hang
    -if project is launched with MojoDX attached in yellow-yellow or yellow-green modes, system will consistently hang after 1 second of playback
    -later today I will try to test with a NitrisDX box as well
    -WORKAROUND: right after the project launch, change the video quality button (doesn't matter if you go back to a yellow mode). This will avoid the crash and you can enjoy a fully functional session. If launching in green-green, you don't need the workaround(see above)
    -project format, framerate and media type seem irrelevant to the issue"
  • Wed, Feb 22 2012 10:20 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    Perhaps that's the first thing to try tomorrow?
  • Wed, Feb 22 2012 10:49 PM In reply to
    • Radman
    • UK
    • Posts 911
    • Points 10,620
    Well, this is interesting.
    I had these same issues with my Multibridge Eclipse. Exactly the same. Have been in touch with BMdesign many times.
    The way I resolved the issue was to uninstal Quicktime, Avid MC6 and BMagic software and drivers.
    Reinstall in this order, Quicktime Pro, Avid MC6 and then BMagic software and drivers.
    The first time I load MC6 always freezes plus white screen. Shut down then load again and all is well. After the first freeze can work all day and night, close Avid reload with no problems. Shut down system then the proceedure starts again.
    Plus sluggish.
    Radman.
    Win10 64Bit / HP Z800-XW8200 / 5x Quadro M6000. 48 Gig Ram / Cubix Expander 4 / 2x 32TB SAS JMR Raid unit / Avid Artist | Avid Artist DNxIO. 3x 27"... [view my complete system specs]
  • Wed, Feb 22 2012 10:54 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    I think thats the order I installed too but another thing to check......
  • Thu, Feb 23 2012 7:15 AM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    This appears to be a serious problem as many people are reporting the same problems from back in November:
    http://community.avid.com/forums/p/106346/615585.aspx#615585
    http://community.avid.com/forums/p/106281/615183.aspx#615183
    http://community.avid.com/forums/p/104494/604467.aspx#604467
    http://community.avid.com/forums/p/106281/615516.aspx#615516
    http://community.avid.com/forums/p/102885/593314.aspx#593314
    http://community.avid.com/forums/p/103735/599566.aspx#599566
    http://community.avid.com/forums/p/104494/605850.aspx#605850
    What is strange is that it is on all types of computer and hardware configurations, even fully qualified ones like mine.
    Does anyone have any solution?  Avid?
