Latest post Wed, Feb 8 2012 7:49 PM by maryd. 2 replies.
  • Tue, Feb 7 2012 12:53 AM
    • Serpus
    • Joined on Fri, Feb 3 2012
    • Posts 3
    • Points 45
    How many clips can my Deko 3000 Dual Channel Play?
  • Wed, Feb 8 2012 7:48 PM In reply to
    • maryd
    • Joined on Wed, Aug 23 2006
    • Posts 12
    • Points 1,895
    • Moderator: Avid Motion Graphics
    Re: How many clips can my Deko 3000 Dual Channel Play?
    You can play 2 clips per Corsica card.  If you system has a single row of connectors on the back of the unit, you have a single card.  You can either play 2 clips on a single channel, or one clip on each channel (presuming you have a dual channel system).
    If you purchased the Clips Deko Plus option, and have 2 rows of sync, input and and output connectors, then you have dual Corsica cards and can play 2 clips on each channel.
    In addition, on Deko3000 you can play Power Clips, which are smaller resolution .mov files.  The limit is not specified by the number of clips, but by the total complexity of the entire graphic.  Generally speaking you can play 3 or 4 Power Clips in addition to the 2 clips per card.
  • Wed, Feb 8 2012 7:49 PM In reply to
    • maryd
    • Posts 12
    • Points 1,895
    To get 2 clips on one channel you must make at least one of the clips a Layer clip.  You can only have one Background clip at a time.
