Latest post Thu, Feb 2 2012 2:10 PM by vpcmike. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Feb 2 2012 4:10 AM
    • markyramone
    • Port Lincoln, Australia
    • Posts 143
    • Points 2,030
    Fit 90 minutes on single side DVD
    I brought a quicktime reference of a 90 minute project in to AvidDVD. No menus or chapter points just a straight DVD that plays by default. However the movie is about 900mb in the red (on a 4.7gb single sided disc). Does anyone know of a formula or method for compressing in Squeeze to a custom duration? Or is is trial and error adjusting the data rate to bring the file size down?
    Mark.
    Avid Media Composer 8.8, Intel Core i7-4790, 3.6 GHz, 16gb RAM NVDIA GeForce GTX 960 Microsoft Windows 10 Home 64 bit [view my complete system specs]
  • Thu, Feb 2 2012 4:33 AM In reply to
    • Posts 10,444
    • Points 221,250
    Re: Fit 90 minutes on single side DVD
    Hello Mark,
    After you have brought the QT reference into AvidDVD you should go to the Preferences (I think it is under "File") and under SD change the bitrate to something smaller than the default.
    I don't have AvidDVD near at the moment, but I think the default is 8,000kb/s, you have to lower that and check the output size again.
    The lower the bitrate - the more you can fit onto a DVD - and the poorer the quality becomes!
    It's all a question of balance. You will probably also have to play around with the CBR/VBR settings there too.
    Regards,
    Douglas
  • Thu, Feb 2 2012 5:05 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,388
    • Points 97,040
    Try 5,500 kb/s VBR and see how you go.  Should get you close with a reasonable quality burn.
  • Thu, Feb 2 2012 7:11 AM In reply to
    I'd go with 5.7Mbps and 192K audio. Should just fit.
  • Thu, Feb 2 2012 11:54 AM In reply to
    • Pinek
    • Joined on Wed, Jan 7 2009
    • Poland
    • Posts 111
    • Points 1,225
    video quality is primary
    set 6200 vbr, 2 passes
    reencode audio to mp3 - 384
    Workstation: AMC 8.3, Windows 7 64-bit ultimate, 4,0 Quad Core, 8 GB RAM, 4 x 1,5TB internal HDD, Nvidia Quadro 4800, LSI HBA, LG Bluray, MOTU HD-SDI.... [view my complete system specs]
  • Thu, Feb 2 2012 12:26 PM In reply to
    • markyramone
    • Posts 143
    • Points 2,030
    Brilliant Douglas!
    Thanks for tripping my memory. I thought there was a way to do this from AvidDVD. FYI the encode settings were under "Project settings" not "Preferences" but  you set me on the right path (and you did say "I think" so I'll let it slide!).
    I can put up with a slight drop in quality, the project was not super high quality to begin with.
    Cheers,
    Mark.
  • Thu, Feb 2 2012 12:28 PM In reply to
    • markyramone
    • Posts 143
    • Points 2,030
    And thanks for everyone's suggested settings! Just glad I didn't need to go in to Squeeze to reduce the file size.
    Mark.
  • Thu, Feb 2 2012 12:45 PM In reply to
    • Posts 10,444
    • Points 221,250
    markyramone:
    Yes Glad to hear you got it sorted.
    Actually I was going to write "Project Preferences" at that time. I know there are 2 similar sounding names involved.
    But all is well that ends well....... As you probably know by now I am a "cut out the middle man" BluRay/DVD creator..... and don't involve Squeeze in my workflow.
    Regards,
    Douglas
  • Thu, Feb 2 2012 1:21 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,140
    If you need to see what your bitrate should be, do a google search for "bitrate calculator" and you will get several links to websites that will let you enter the time of the video and will then tell you the correct bitrate.
    System #1 - Mac Pro 12 Core 2.93, 24 GB RAM, 16 TB ISIS 5000 System #2 - Core i7 2600k, Windows 7, 16 GB RAM, Quadro 4000 System #3 - Dell Precision... [view my complete system specs]
  • Thu, Feb 2 2012 1:51 PM In reply to
    • Posts 10,444
    • Points 221,250
    vpcmike:
    There is a very basic (inaccurate?) bitrate calculator in AvidDVD, where you set your media type.
    Regards,
    Douglas
  • Thu, Feb 2 2012 2:10 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,669
    • Points 20,140
    Didn't know that - we use Encore for all of our DVD's and we always run QT Ref files thru Sorenson first.  Always nice to learn new things!
