Latest post Tue, Jan 17 2012 9:57 PM by jesusonline. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Sun, Jan 15 2012 2:28 PM
    The toughest error I even encountered
    Hi , dear community.
    Last week I encountered my toughest error yet on MC  -  we're working on 4.0.5
    in a big project filmed mostly on SONY XDCAM  and Transcoded to 15:1  on the avid unity
    working in PAL.
    we have been working on this project for half a year by now , and suddenly at the middle of the project , our offline master editor project has this nagging error when saving or trying to close the bin
    the error basically says  "ACCESS VIOLATION"
    I have tried working without the media and it still occurs
    and Without audio tracks and it still occurs
    I have also thrown out the effects and it still occurs.
    We have also called out the AVID representatives and they basically said  :  "something is messed  up and it's your problem now "
    even taking the bin to a new project raises the error  and even with a new user
    We tried desperately to find the problem but with no help
    please if anyone can help
    this is kind of important!
    the errors I am getting are : " Access violation"
    and  " EXCEPTION:DOMAIN COPYIN FAILED"
    Thanks a lot
    Tom David
  • Sun, Jan 15 2012 2:36 PM In reply to
    Re: The toughest error I even encountered
    Hi Tom
    Access violation errors are pretty common, so hopefully something in these search results relates to your situation:
    http://tinyurl.com/86ruevg
    If not, post back here and let us know what operating system you're running.
    ciao,
    Carl
  • Sun, Jan 15 2012 2:54 PM In reply to
    Yes I know, It is a common error .  but this one is really stubron - and even when all medias are offline  it still occurs
    we really tried to locate the problem within the sequence but it is not only in 1 sequence but in several  almost like it spreads out
    our OS is WINDOWS XP SP2 I believe
    but the Sequence will come up with errors in various avid versions including version 6
    it's as if suddenly the avid says " I don't want to work with you"
  • Sun, Jan 15 2012 3:54 PM In reply to
    • Posts 11,208
    • Points 231,180
    Tom,
    That sounds awfully odd that an Avid employee would say somethihgn like that - not common behavior I can assure you.
    Could you respond back to me via email and let me know who you spoke with - also provide your contact info. so i can either get you to support or have a tech reach out.   I am out Monday thru Wed but I will be online later today so hopefully you can respond quickly.
    Standing by... email address is below.
  • Sun, Jan 15 2012 4:12 PM In reply to
    Things to try
    1. "Divide and Conquer". Subclip to a new bin to see if you can pinpoint the specific track and/or clip the causes it.
    2. "repairsequences" command in the console while the bin is open. Avid will check the relationship of the sequence to the media.
    3. New user, localize (if using Unity/ISIS) the project, new project, etc.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Sun, Jan 15 2012 4:13 PM In reply to
    Are you running Windws XP "Pro" or "Home"?  Meanwhile, an "Access Violation" can be pointing to the Project itself, and it may be a permissions issue.  Reset the ownership by following this procedure.  Also, the error "EXCEPTION:DOMAIN COPYIN FAILED" often is the result of a corrupt Bin.  Try loading a backup copy from the Avid Attic.
    (wwld)
  • Sun, Jan 15 2012 4:28 PM In reply to
    I have tried  All of these thing already,
    none help
    I can send you the bin
    and you can probably cut it to 3 minutes and it still crashes
  • Sun, Jan 15 2012 4:33 PM In reply to
    "... I have tried All of these thing already ..."
    Whose suggestions are you responding to?
    (wwld)
  • Sun, Jan 15 2012 4:38 PM In reply to
    And since working on the Unity , so there are no PERMISSIONS issue as I understand
    working on XP pro
    and as for the DOMAIN ERROR
    Maybe something corrupts our bins
    How about if the number of folders was around the 10,000 limit on the unity system??
    jesusonline:
    zip it and send it over
  • Sun, Jan 15 2012 4:52 PM In reply to
    "... How about if the number of folders was around the 10,000 limit on the unity system?? ..."
    Unity uses "Dynamic Allocation" (something I suggeted in 1999/2000 btw).  When you exceed 10,000 directories (folders), Avid starts the process.  Each time you cross a 10,000 limit, you get an additional 10,000, and lose 32,000 files from the 500,000 max file count.
    "... And since working on the Unity , so there are no PERMISSIONS issue as I understand ..."
    Correct, I missed the Unity part on first read.
    (wwld)
  • Sun, Jan 15 2012 5:04 PM In reply to
    Filed under: ,
  • Mon, Jan 16 2012 7:43 AM In reply to
    UPDATE:
    I have tried relinking one of the problematic sequences to the online XDCAMS  and transcoding
    but found it impossible as every relink  and transcode tries to save and the avid crashes
    this means I practically have to stop working on the project and consider rolling back a week expensive work.
    Thank  you guys
    p.s.
    and nothing guarantees me the problem won't come back
  • Mon, Jan 16 2012 9:13 AM In reply to
    Is this the latest version you can use?
    I mean 4.0.5?
    Have you cleaned the database files?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
    Did you send Marianna an email?  Her email address is at the bottom of her post.
