Latest post Thu, Jan 12 2012 6:36 PM by camoscato. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 12 2012 4:44 PM
    Command pallette wont close
    Dear all,
    I have discovered an annoying bug with my new Avid MC 5.5, my command pallette is stubbornly open and I can't close it. It seems it wedged itself to the very top of avid window and hides its controls (such as minimize, close and maximise) under the Avid top panel. I can't move it, I cant close it and it sits in the middle of my screen. I am attaching a screen grab. I tried to close, changed user settings etc and nothing works. Any ideas?
  • Thu, Jan 12 2012 5:16 PM In reply to
    Re: Command pallette wont close
    Not sure if this will work, but click on the Command Palette to make it active, then press CTRL+' (apostrophe).  This is the Home command (also available under the Window menu, I think), and it puts the selected window back where the system "thinks" it should be.
    If that doesn't get it, does CTRL+w close it?
    ciao,
    Carl
  • Thu, Jan 12 2012 5:28 PM In reply to
    Hi Carl,
    I tried both but no luck, it looks it not fully functional... I may have to reinstall Avid ... A major headache but thanks! Any other ideas?
  • Thu, Jan 12 2012 6:00 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 462
    • Points 5,590
    what happen when you load another toolset or workspace? Or change your display resolution?
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Thu, Jan 12 2012 6:01 PM In reply to
    Exit MC and then delete the MCState setting.  When you restart maybe the window will go someplace useful.  If not that, try a new user and a new project.  If that doesn't get it, I'm out of ideas.
    [edited to add] Try Kristina's ideas first.
  • Thu, Jan 12 2012 6:26 PM In reply to
    Thanks, I tried the resolution trick but wil try the rest, Where do I find the MCstate setting?
  • Thu, Jan 12 2012 6:36 PM In reply to
    I've got 6 of them scattered all over my system, so my suggestion is to type "mcstate" into the Windows search on the Start Menu and find it that way.
