Latest post Thu, Dec 22 2011 5:05 PM by snye. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Dec 21 2011 4:42 PM
    • Brian
    • Joined on Tue, May 24 2011
    • Posts 16
    • Points 210
    Sorenson Squeeze 7 Crashes
    Just installed MC 6.0 recently (on a brand new clean system) along with Squeeze 7. Tried S7 for the first time just now and it keeps crashing after rendering completes. Anyone else seen this? Did it four times. Three times it crashed. One time it did not crash. Settings were the same each time.
    Used the Iphone 3GS preset but changed code to Apple H264, data to 1000, 640X480.
    MC 6.0 Mac Dual 2.93 X 6 Core (Westmere), 32GB Ram, ATI Radeon 5870 [view my complete system specs]
    SYSTEM:
  • Thu, Dec 22 2011 5:05 PM In reply to
    • snye
    • Joined on Thu, Dec 22 2011
    • Posts 1
    • Points 5
    Re: Sorenson Squeeze 7 Crashes
    Does it crash if you use an unmodified default preset? Is there a reason you chose the Apple h.264 preset? It is generally of less quality than the Main Concept or Sorenson h.264 presets. I would recommend starting with the default preset and change one setting at a time to try to determine which setting is causing the crash. I also recommend using your same serial number and install version 8 of squeeze. You can get it at www.sorensonmedia.com/downloads.
