Latest post Thu, Dec 15 2011 1:36 AM by Larry Rubin. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Dec 13 2011 10:20 PM
    • duckyou
    • NJ
    • Posts 193
    • Points 2,260
    Quick question
    There are two simple things that have changed over the last few versions that I haven't figured out.
    Been meaning to ask for some time now.
    1. How can I change my windows to 4:3 when in a 16:9 project?  (Used to be a simple right click on the program window)
    2. When using the "red move tool" what has replaced "control" for keeping it locked in place horizontally?
    Thanks for your help
    Mac 8 core, 12gB ram, OX 10.8.4, Media Composer 7.0, AJA IO Express or Matrox Mini Max [view my complete system specs]
  • Wed, Dec 14 2011 12:05 AM In reply to
    Re: Quick question
    Go to format tab and switch it there from 16:9 to 4:3 and vice versa.
    There is the Smarto Tool for those things but I am not sure what you mean.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Dec 14 2011 1:26 AM In reply to
    • duckyou
    • NJ
    • Posts 193
    • Points 2,260
    Re: Quick question
    Thanks for your reply,
    Unfortunately, the format tab only works when you are in NTSC or PAL.  Once in an HD format it is grey'd out.
    I've often needed to use the same material for multiple purposes and it was very convenient to be able to toggle between the the two formats to resize and gauge proportion.
    As for the "Smart Tool"  As an example, if I want to move an audio track to a different track, without losing sync, I was able to click on the red arrow, hold the control button and drag it up or down without it moving +/- from sync.
    Now if I do that a menu appears.  I know it is probably some similar keystroke, but that's what I'm asking for.
  • Wed, Dec 14 2011 1:49 AM In reply to
    Re: Quick question
    Yes this is natural as there is no 4:3 HD ;)
    Ctrl + works here on PC.
    But there are issues with Ctrl + or Alt+ at MC6.
    Desktop PC
  • Wed, Dec 14 2011 1:50 AM In reply to
    Re: Quick question
    duckyou:
    It is now CMD + SHIFT to drag vertically and stay horizontally constrained. See this comprehensive list of Media Composer Keyboard Shortcuts.
  • Wed, Dec 14 2011 2:02 AM In reply to
    • duckyou
    • NJ
    • Posts 193
    • Points 2,260
    Re: Quick question
    Larry,
    As always, you're da man.  Thanks and happy holidays!
    Chuck
  • Wed, Dec 14 2011 2:15 AM In reply to
    Re: Quick question
    You're quite welcome, Chuck. Always glad to help out. And Happy Holidays to you and yours, too!Yes
  • Wed, Dec 14 2011 2:26 AM In reply to
    Re: Quick question
    duckyou:
    You can still do that.  Right-click on the Composer window>Project Aspect Ratio and choose 16:9 or 4:3.  But, as pointed out - the option is greyed out in HD.
  • Wed, Dec 14 2011 2:37 AM In reply to
    • duckyou
    • NJ
    • Posts 193
    • Points 2,260
    Re: Quick question
    Thanks Kenton,
     it's sad that we still get requests for 4:3 versions of projects and I was probably the only one using the format toggle for this.  I currently change the format to NTSC and work that way. Just another step in a day filled with many steps.
  • Wed, Dec 14 2011 4:34 PM In reply to
    Re: Quick question
    Remember that in an SD project, you aren't changing the size of the frame when you switch from 4x3 to 16x9 and vice versa...it's still a 720 x 486 image.  You're just changing whether you're viewing it anamorphically or not.
    In HD, since there is no 4x3, you actually have to change the frame size from 1920x1080 to 720x486, for example.  That's why you have to switch the project type.
    If you have hardware I/O, you can use the "downconvert" option to work HD and display a letterbox, anamorphic, or center cut SD version at the same time.
  • Thu, Dec 15 2011 1:27 AM In reply to
    • duckyou
    • NJ
    • Posts 193
    • Points 2,260
    Re: Quick question
    Thanks Kevin,
    I do understand that.  It was purely a visual reference for resizing at export.  I would throw up the 4:3 window, resize so that it looked good and although it looked squished or stretched back in the 16:0 window it exported perfectly.
    Using the IO to do the same thing is a brilliant suggestion.
  • Thu, Dec 15 2011 1:36 AM In reply to
    Re: Quick question
    Another very helpful tool I use quite often is the "4:3 inside 16:9" mode of the grid tool
