Latest post Mon, Dec 12 2011 10:09 PM by Mark.C. 2 replies.
  • Mon, Dec 12 2011 9:43 PM
    • Mark.C
    • Joined on Thu, Sep 29 2011
    • Posts 17
    • Points 220
    How to re-import footage for final output
    Hi
    I have just completed a short 3 min edit using footage from a Canon 5DmkII. When I orgiginally imported the footage ( 3hours in total) i imported it using the DNxHD 36 codec so that i could smoothly edit it on my laptop. Now the edit is complete how do I rebatch the footage DNxHD 185 for the final output?? Is there a way to only import the clips I have used or do I have to reimport everything??
    Any advise is greatly apriciated
  • Mon, Dec 12 2011 9:50 PM In reply to
    Re: How to re-import footage for final output
    Select the Sequence in the Bin and choose Batch Import from the right-click menu.
    When the dialogue box pops up all your shots and their original import file locations should be in black, (if they're red, then Avid can't locate the originals and you'll need to point it to where they now)
    Then under Import Resolution, choose DNx185 and that should be it I believe.
    It will import only the clips used in the sequence, however it will import the whole file for the clip section used.  So, if you had an original file that was 10 mins long, but only used 10 secs of it, the entire 10 mins has to come in.  Make sure you've got plenty of space.
  • Mon, Dec 12 2011 10:09 PM In reply to
    • Mark.C
    • Posts 17
    • Points 220
    Amazing
    It worked thank you so much for your help
    Mark
