Arri Alexa LUT Color Correction Effects
Click the link to download.Extract the zip file and open the bin in your Avid project.
Apply the Color Correction Effect on an Alexa logC clip or put it on an empty track above to view the footage in linear space with gamma and highlight roll off.
Legal maps the footage to 16-235. Extended maps the footage to 0-255.
Note: The effects are basically 1D LUTs (8bit with 16 samples) and they don't convert properly to Rec709 colors.In an attempt to fix that I added a little saturation to the effects with the suffix "SatBoost".
Cool feature:Since the s-curve is downstream in the color corrector you can set the exposure by adjusting Brightness in the HSL tab.
A brightness value of 18 should be similar to one stop in exposure. (36 = 2 stops and so on.)Add some punch with Contrast if the Brightness adjustment washes out the image.
Jorgen Persson
Thanks for sharing!!
AWESOME WORK, MAN!!!
Avid should include this into their standart effects palette!!!
http://tobiassuhm.com/
Thanks for a great greeting to Sweden. Saved me a lot of time.
V.
I get this when I hit the link :-(
Reported Attack Page! This web page at avocoda.com has been reported as an attack page and has been blocked based on your security preferences. Attack pages try to install programs that steal private information, use your computer to attack others, or damage your system.Some attack pages intentionally distribute harmful software, but many are compromised without the knowledge or permission of their owners.
Symphony 2018.11, Blackmagic Intensity Pro (cant get it working well in 4k though for client monitor - which was the point...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
updated link
