Latest post Tue, Jun 19 2012 1:28 PM by Larry Rubin. 4 replies.
  • Thu, Dec 1 2011 5:53 PM
    MC 6 will not launch- Disk Invalid Filename Syntax..?
    Avid phone is no help.
    I own a valid copy of MC 5.5 but want to try version 6. I uninstalled 5.5...installed ver 6 and it will not launch. It gets hung up Initialzing Avid Media Access Volume Manager...then it quits and I get a window that reads: Exception: DISK INVALID FILENAME SYNTAX.
    I have no idea what any of this means.
    I tried several times uninstalling and re-installing ver 6 but each time - same result.
    I then fully erased my System drive and did a fresh install of 10.7.2...My Mac pro was clean of anything Avid. It was basically a new machine. Nothing else installed. Just the OS.
    I once again downloaded version 6....installed.....and I STILL get the same Issue.(?)
    Anyone else have this happen?
    Is it a Lion OS issue? Do I need to set a folder a certain way? I just do not get it.
    What is the bottleneck here?
  • Thu, Dec 1 2011 6:06 PM In reply to
    Re: MC 6 will not launch- Disk Invalid Filename Syntax..?
    Just read the error...
    What's the name of your hard drive?  Does it have a slash ( / ) or other weird characters in it?
  • Thu, Dec 1 2011 6:48 PM In reply to
    • Bokes
    • Posts 219
    • Points 3,205
    yes we found it- an external was being read but wasn't displayed on the desktop.
    Thanks!
  • Tue, Jun 19 2012 1:23 PM In reply to
    I had the same problem. As it turned out, a Korean audio cd was the problem: very suspicious data!
  • Tue, Jun 19 2012 1:28 PM In reply to
    Randolph Duke:
    I know this is an old thread, but Randolf if you're still around, would you please elaborate on that? Who did you call and what response did you get?
