Latest post Tue, Nov 29 2011 8:47 AM by Allan. 7 replies.
  • Sat, Nov 19 2011 2:02 PM
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Is there a way to see who are locked in to the ISIS5000 server?
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Sun, Nov 20 2011 5:44 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 462
    • Points 5,590
    Re: Is there a way to see who are locked in to the ISIS5000 server?
    Hi Allan,
    do you mean which client is logged in by isis-client to the storage or who is logged in to the management console?
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Thu, Nov 24 2011 5:12 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,321
    • Points 25,890
    On the System Director, open the ISIS system director control panel-  then click on "Active Clients" tab.
    bam!Do
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
    Filed under: ,
  • Mon, Nov 28 2011 12:38 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Thank you Doc.
    To open the System Director i understand have to be done from the "ISIS lunch pad"
    How do i make the "ISIS lunch pad" active on my PC?
    Allan
  • Mon, Nov 28 2011 1:28 PM In reply to
    • Kristina
    • Germany
    • Posts 462
    • Points 5,590
    Hi Allan,
    you can login to the management console from every client by typing the ip-address of system director in your IE and login with the same username and password you use by logging-in at the system director itself. Then follow Doc Avids advice to the "active clients tab".
    Also you need flash player to be installed on your client.
    But be careful that you don´t do any administrative parts in parallel on open management consoles. It is an administrative console not for every editor to be open for viewing.
    You can make user accounts with limited access but I´m not sure if these accounts can see the active clients tab as well.
    Try it yourself Wink
    Best regards,
    Kristina
  • Mon, Nov 28 2011 1:47 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Thank you Kristina for being helpfull.
    Typing the ip-address of system brings me to the Management console and not the system director, or launch pad.
    Or should i first install AvidISISStorageManager64.msi on my PC ?
    Best regards
    Allan
  • Mon, Nov 28 2011 6:15 PM In reply to
    • Kristina
    • Germany
    • Posts 462
    • Points 5,590
    Hi Allan,
    the info you are looking for is also in the management console. On condition that you know the admin username and password. Otherwise you see less information.
    But even with limited access you should see the connected clients (see screenshot lower left)
    Otherwise click connection status or bandwidth from connectivity icons. Or are you still missing other information?
    Best regards,
    Kristina
  • Tue, Nov 29 2011 8:47 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    What I see in the management console is connected workstations but not the individual users.
    We do have 13 workstations that more than 50 user/clients are using, all with individual lock in. We are interested to know users working and when. Preferably as a history log.
    Best regards
    Allan
