Latest post Sun, Nov 13 2011 10:37 PM by Job ter Burg. 3 replies.
  • Sun, Nov 13 2011 8:30 PM
    • mar/cus
    • Joined on Mon, Nov 7 2011
    • sweden
    • Posts 102
    • Points 1,420
    Different 1:1 MXF
    What is the difference between 1:1 MXF, 1:1p 10b MXF and 1:1 10b RGB MXF?
    Anoter question. If I import video footage in DNxHD 185 and edit, and than import music uncompressed 1:1 will the music transcode or something to DNxHD when I put it in the timeline?
    MacPro 2013 Quad-Core - Dual AMD FirePro D300 - 32GB Memory, PROMISE Pegasus2 R6 18 TB, Blackmagic Ultrastudio Express, Avid Omni HD Native, Artist Mix... [view my complete system specs]
    Filed under: , , , ,
  • Sun, Nov 13 2011 8:56 PM In reply to
    Re: Different 1:1 MXF
    1:1 is interlaced 8-bit, 1:1p is progressive 8-bit, RGB is the RGB-444-version, 10b is the 10-bit version. Sound will not transcode to a video resolution, it gets imported as either PCM-MXF, OMF-WAV or OMF-AIF, depending on your Audio Project settings. It will not be compressed, but it may be sample rate converted or bit depth converted. Nothing happens with the source files if you place them onto a timeline.
  • Sun, Nov 13 2011 9:27 PM In reply to
    • mar/cus
    • sweden
    • Posts 102
    • Points 1,420
    Cool, thanks!
    Which of PCM-MXF, OMF-WAV, OMF-AIF has the best quality?
  • Sun, Nov 13 2011 10:37 PM In reply to
    They are all the same, uncompressed audio, just in different containers.
