Latest post Tue, Oct 25 2011 4:26 PM by mjolnarn. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Oct 25 2011 3:34 PM
    • Tammie
    • Orlando
    • Posts 20
    • Points 250
    Firewire decks not recognized by MC 5.5
    Relevant System Specs:
    System: Mac Pro (2011), Snow lepoard, FW 800 ports only, Media Composer 5.5.2, Matrox MXO 2 Mini for client monitoring
    Decks: Sony DSR-25 & DSR-1600
    The problem is when I hook up either of the decks (only every hook up one at a time), they show up in the system profiler, but the Avid does not see them. I am using a converter on my firewire cable to go from 400->800.
    I have a identical machine, minus the Matrox MXO 2 Mini, that sees all these decks fine as generic devices even using the converter from 400->800. The Matrox MXO 2 doesn't have any firewire on it, so I wouldn't think it would cause any problems, but at this point I have no idea.
    Any suggestions?
    Thanks.
    2013 Mac Pro (trashcan) - Yosemite 10.10.1, 3.7GHz Quad-Core Intel Xeon E5, 16GB Ram Avid Media Composer 8.200 [view my complete system specs]
  • Tue, Oct 25 2011 4:01 PM In reply to
    Re: Firewire decks not recognized by MC 5.5
    When you say "doesn't see them" are you referring to audio/video or control, or both?
  • Tue, Oct 25 2011 4:10 PM In reply to
    • Tammie
    • Orlando
    • Posts 20
    • Points 250
    Both. I use the auto configure deck option in the digitize tool and nothing happens. I also tried manually adding it using the deck configuration setting window, but again nothing.
  • Tue, Oct 25 2011 4:14 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,345
    Tammie:
    Just click on the Matrox ikon below the sequense viewer so that it is switched to 1394 instead
    Tomas
  • Tue, Oct 25 2011 4:22 PM In reply to
    • Tammie
    • Orlando
    • Posts 20
    • Points 250
    That was it! Thanks so much. For anyone else having this problem you can change it under the Special menu, and then go to device. It will list the MXO2 and IEEE, switch to IEEE.
  • Tue, Oct 25 2011 4:26 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,345
    You´re welcome, have a continued happy editing
    Tomas
