Latest post Thu, Feb 21 2019 2:26 PM by mikela. 51 replies.
Page 4 of 4 (52 items) < Previous 1 2 3 4
  • Tue, Feb 25 2014 9:34 AM In reply to
    Re: OSX Lion & Media Drive Issue could result in Segmenation fault error
    Thanks for this, very helpful. Was wondering why I was getting the 'Segmentation Fault at 0' etc whenever tried to open a project file, swiftly followed by a crash. Was ok though to open the Avid app on its own though, then select the project - no crash.
    "Ah.  right.  Here's something fun for anyone who hasn't yet upgraded to Lion (like me)"
    Word of advice: DON'T :D
    MBP Mid 2014 2.5 Ghz Intel Core i7. 16 GB 1600 MHz DDR3 Intel Iris Pro 1536 OSX Yosemite 10.10 [view my complete system specs]
    Refugee from the FCP bloodbath!
    Shortcuts sought:
    1) SELECT KEYFRAMES
    2) ENTER SLIDE MODE
    3) SHOW KEYBOARD
    4) NAVIGATE FROM ONE TAB TO ANOTHER IN PROJECT MENU
    5) NAVIGATE FROM HAVING A BIN SELECTED, TO SCROLLING DOWN/ NAVIGATING WITHIN THE BIN
    6) ZOOM IN TO EFFECTS EDITOR KEYFRAME TRACKS
    7) LABEL CLIPS
    8) MOVE CLIPS AROUND VERTICALLY ON TIMELINE
  • Tue, Mar 4 2014 2:42 AM In reply to
    Okay scratch that. Changed permissions to read & write in 'Macintosh HD' and in Users/Shared/AvidMediaComposer, Avid, AvidBinIndexer and AVX Plug-Ins Data and all sub-folders. Still getting:
    Shortcuts sought:
    1) SELECT KEYFRAMES
    2) ENTER SLIDE MODE
    3) SHOW KEYBOARD
    7) LABEL CLIPS
  • Wed, May 21 2014 9:52 AM In reply to
    • mivko
    • Joined on Sun, Aug 4 2013
    • Posts 13
    • Points 125
    Jakob Peterhänsel:
    Larry Rubin:
    that is Avid's official recommendation for dealing with a segmentation fault error that started with the Lion OS series.
    Well, that just makes it even worse!
    Never ever make users compromice system security as a 'quick fix'!
    The right solution is to create the folder Avid MC would like to see there, and make access to that folder.
    This is a very old thread, but I was also shocked to see this recommendation of making the whole system drive read/write.
    To create an Avid MediaFiles folder on the system drive, one can use the following 3 commands in Terminal, which will not modify the rest of Mac OS permissions:
    sudo mkdir -p "/Avid MediaFiles/MXF/1"
    sudo chown -R "$USER:staff" "/Avid MediaFiles"
    sudo chmod -R a+rwX "/Avid MediaFiles
    The first command will ask for the user password, and then create the folders, The second changes the ownership, and the last one gives everyone read/write access to this folder and it's sub-folders (and not to the rest of the system!)
  • Wed, Jan 28 2015 12:40 AM In reply to
    • Thomas
    • Joined on Sun, Feb 23 2014
    • Cologne
    • Posts 52
    • Points 715
    Re: OS X Media Drive Permissions Issues
    after i have copied the project to an external drive, i am getting following message, when I want to save the project:
    Project settings is not saved due to an error.
    Exception: Recource temporally unaivailable, filname: Gaensacker_Ausgrabung.avp
    This happenes only with Mac. With Windows I do not get that error-message. So there seems to be a write-problem occured by missing write-permissions to this external Drive. Is there any command für that. "Alldrives" I have tryd yet. in the information window shows me, that everyone has read & write permission & there is the problem, a error-message appears that I  can not add an user, in cause of missing permissions. It is a NAS-Drive, connected via Thunderbolt to LAN-Adapter
    Network-settings of the MBPro are IP4: DHCP and IP6: automatic.
    this must be a mac-os-only-problem, because with windows it works.
    The NAS-Drive is managed by Linux. Of course I have given me total Adminitrative-rights. But there seems to be a (protocol-) conflict or something similar. I am not expert enough for IT-Administration-things.
    Any Ideas?
    Doing regular manual saves are still the only way to be sure your work is secure and its a trick old school editors won't drop. [view my complete system specs]
    Thomas Poerschke, Editor & Colorist
    ColorGrading.TV @ MMC Studios Köln, Am Coloneum 1, 50829 Cologne, Germany
    web: www.colorgrading.tv
  • Wed, Jan 28 2015 2:40 PM In reply to
    • Chepal
    • germany
    • Posts 538
    • Points 6,290
    you'll need software for your mac to read/write windows/linux_formatted_drives.
    my two cents
    che
    mac_mc_2020, fibre, sata, ssd [view my complete system specs]
    peace from germany
  • Wed, Jan 28 2015 3:04 PM In reply to
    • mivko
    • Posts 13
    • Points 125
    You seem to not be using an "external drive", but a network share on a different machine (your NAS server) instead.
    I don't think that you can do that with your projects folder. Network shares are very different from local drives (whether internal or external).
    Use your NAS for backups, storage, etc. but put your projects, settings and Avid MediaFiles on a local drive.
    Anyway, this should really be in a separate thread since it doesn't seem related to "OS X Media Drive Permissions".
  • Thu, Feb 21 2019 2:26 PM In reply to
    • mikela
    • Joined on Thu, Jul 28 2011
    • Posts 125
    • Points 1,405
    This is weird - I keep loosing permissions to write to drives.
    I have my boot drive, a 2nd partition called "MEDIA" that I created when I lost permissions to write to the boot drive AND an external drive mounted. When I click to import, it says "There are no media drives available..." I made the 2nd partition specifically because I couldnt import to the boot drive anymore. Nothing has changed on my end (in the avid).
    MC8.9.4 running on OSXEl Cap 10.11.6 - I haven't done any updates that would lead to drive permissions chaning. I have checked and "everyone" has Read & Write permission on all drives. There is no "wheel" user listed anymore. Any ideas?
    update: I can drag and drop into a bin, and the media will be created on my external drive - BUT I still cant import in the normal way.
