Latest post Thu, Feb 21 2019 2:26 PM by mikela. 51 replies.
Page 2 of 4 (52 items) < Previous 1 2 3 4 Next >
  • Mon, Jul 23 2012 12:16 AM In reply to
    • jssamaty
    • Joined on Fri, Jun 29 2012
    • Posts 9
    • Points 80
    Re: OSX Lion & Media Drive Issue could result in Segmenation fault error
  • Tue, Sep 11 2012 11:26 PM In reply to
    Yes Thanks!
    Mac OS X 10.10.5 Yosemite Avid MC Vers v8.6.5 with MX02 4.6.0 (Firmware 15) Mac Pro 2.66GHz 12 Core 12GB / 1TB Solid State Drive w/ 48 GB of added ram... [view my complete system specs]
    "If you don't know where you're going, any road will get you there.." Alice in Wonderland. feelm
  • Tue, Oct 9 2012 5:34 AM In reply to
    Re: OSX Lion and Media Drive Issue
    Hello I am a student in my first year and I keep getting the same problem. I have a OSX 10.8.2 I'm really behind in my class everytime I open Avid it, it crashes saying segmenation fault error.
    What is a writable avid media files folder?
    Also, I have changed my settings to read and write on my sharing and permission. It still crashes do I uninstall avid then install it again?
  • Tue, Oct 9 2012 5:42 AM In reply to
    Hi I just wondering if you ever figured this out? I'm having the same problem...
  • Tue, Oct 9 2012 6:12 PM In reply to
    http://c2.avid.com/forums/p/101235/583040.aspx
    give this a try
  • Sat, Oct 20 2012 11:29 AM In reply to
    Todd Sanderson:
    For customers that don’t intend to use the system drive for media, they can leave it as is. This is ideal in most cases.  For those that need to use the system drive, they should take the following steps to change permissions:
    I'm impressed, and scarred at the same time, that a Moderator can suggest to bypass basic security on the system!!
    What should be the suggestion, is to use an Admin account to create the needed Avid MediaFiles folder, and then set the required read/write permissions on that folder, not the complete root of the system drive!!!!!
     Jakob Peterhänsel
     Freelance Consultant
  • Sat, Oct 20 2012 3:07 PM In reply to
    Jakob, that was not a moderator created recommendation, that is Avid's official recommendation for dealing with a segmentation fault error that started with the Lion OS series.
  • Sat, Oct 20 2012 3:48 PM In reply to
    Larry Rubin:
    Well, that just makes it even worse!
    Never ever make users compromice system security as a 'quick fix'!
    The right solution is to create the folder Avid MC would like to see there, and make access to that folder.
     Jakob Peterhänsel
  • Sat, Oct 20 2012 3:56 PM In reply to
    If you feel that strongly about it, then you should contact the Avid office in Denmark from this list.
  • Mon, Dec 24 2012 5:30 PM In reply to
    • azpackrat
    • Joined on Tue, Apr 7 2009
    • Phoenix AZ
    • Posts 40
    • Points 610
    Uh, okay, brand new Mac user here. I'm getting the segmentation error - using Lion - and thought I'd try your solution. So exactly how do I do step one? When I go into the Finder, there is nothing that identifies the system HD, just the components on the drive.
    AMC6 v6.0.3 on MacBook Pro 15" OSX 10.7.5 - 4GB Ram 2.4GhZ Intel Core i7 with AMD Radeon HD6770M and external Lacie Media drive [view my complete system specs]
  • Mon, Dec 24 2012 7:03 PM In reply to
    Gary:
    Right click on the Macintosh HD alias on your desktop and choose "get info". In the next window, down at the bottom you will see a twirly for "Sharing & Permissions". If you don't have a Macintosh HD alias on your desktop, in Finder go to File>Quick Look "Macintosh HD", then "Open Volume". Right click on Macintosh HD there.
  • Sat, Mar 16 2013 11:49 PM In reply to
    • AlexKost
    • Joined on Sat, Mar 16 2013
    • Posts 1
    • Points 15
    Re: OSX Lion/Mt. Lion & Media Drive Issue results in Segmenation fault error
    Since you can't highlight the Macintosh HD drive in Mountain Lion, is there any other way to do this? Or is Avid MC 6.0.1 still not properly compatible with OSX 10.8.2?
  • Sat, Mar 16 2013 11:53 PM In reply to
    No, 6.0.1 is not compatible with OSX 10.8.2. See this version matrix for complete version/OS compatibility details.
  • Tue, Jun 18 2013 2:44 AM In reply to
    • mali lina
    • Joined on Fri, Jan 25 2013
    • United States
    • Posts 3
    • Points 10
    I have know this now!
  • Thu, Aug 22 2013 7:31 PM In reply to
    • dkennard
    • Joined on Tue, Oct 2 2012
    • Posts 9
    • Points 130
    I'm on Mac experiencing exactly the same problem multiple times daily.  It's happened on every version since MC6, I've tried every update, every patch and made sure I've always had a supported configuration.  I'm now on 7.0 and still get the "segmentation fault 0x0" crashes at least once a day.
    I've made the permissions change mentioned above and maintained the setting on my system drive, but it has never stopped the segmentation fault crashes.
    My clients are getting seriously annoyed with this and I am beyond frustrated.  Have you got a fix for me?
    If there isn't one soon, I'm probably switching to Premiere Pro. I've been testing it extensively since Adobe released CC and have not a single crash.  There's much I would miss about Avid, but the constant crashing (not to mention the extremely sluggish UI...) are slowing me down.
    My system specs are:
    Media Composer Version 7.0.0 with Symphony Option
    Model Name: Mac Pro 5.1
    Processor  3.33 GHz 6-Core Intel Xeon
    Memory  16 GB 1333 MHz DDR3 ECC
    Graphics  ATI Radeon HD 5770 1024 MB
    Software  OS X 10.8.4 (12E55)
    Many thanks for you help.
