Latest post Thu, Sep 29 2011 5:15 AM by zooce. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Sep 28 2011 1:11 AM
    • zooce
    • Joined on Sat, Jul 2 2011
    • Posts 22
    • Points 250
    4:3 footage with 16:9 footage
    How can I get 4:3 footage into my 16:9 sequence without stretching it?
    Dana
    27" iMac (late 2009 model), OS X 10.6.8, 2.8 GHz Intel i7 Quad Core, 4 GB of RAM, Pro Tools 9.0.5, MC 5.5.3 (student), M-Audio ProFire 610, Dynaudio... [view my complete system specs]
    Don't forget about sound!
  • Wed, Sep 28 2011 1:27 AM In reply to
    Re: 4:3 footage with 16:9 footage
    Here's what I do:
    import / edit / use REFORMAT effect (adjust accordingly)
    Ervz Tia | Video Productions
    Filed under: , , ,
  • Wed, Sep 28 2011 3:34 AM In reply to
    • zooce
    • Posts 22
    • Points 250
    Thanks I'll give that a try.
  • Wed, Sep 28 2011 3:50 AM In reply to
    • zooce
    • Posts 22
    • Points 250
    Worked perfectly, thank you tikboy.
  • Wed, Sep 28 2011 5:41 PM In reply to
    • adonis
    • Dubai, UAE
    • Posts 65
    • Points 860
    You can also tag your clips in the bin, then they'll be treated correctly when you add them to your timeline. To do so, make sure you're in Text view, and that you're showing the Pixel Aspect Ratio, Image Aspect Ratio, and Reformat. Here you can tag your clips properly, and select in Reformat how Media Composer should treat it if and when you drop your clips in a timeline of a different aspect ratio. You can easily to it to one clip at the time, or select a bunch of them in the bin and change them all.
    MC v5.5.3, HP Z800, Windows 7 64-bit, 8GB RAM, Mojo DX and AJA io Express, ISIS 5000 [view my complete system specs]
    "There will come a time when you believe everything is finished. That will be the beginning." (Louis L'Amour)
  • Thu, Sep 29 2011 5:15 AM In reply to
    • zooce
    • Posts 22
    • Points 250
    Awesome! Even better, thanks a lot!
